door switch
Old Dec 23, 2004 | 11:20 PM
ford390gashog's Avatar
ford390gashog
door switch
where can i find new replacement door switches for the dome light
Old Dec 23, 2004 | 11:22 PM
Torque1st's Avatar
Torque1st
Posting Legend
Any good auto parts store.
When you get them they will look to be way too long. The length is adjustable. Just install the switch and close the door slowly and it will "self adjust". Make sure you use dielectric grease on the switch and connector.
Old Dec 24, 2004 | 12:22 AM
ford390gashog
what is the actual name of the switch
Old Dec 24, 2004 | 12:35 AM
Torque1st's Avatar
Torque1st
Posting Legend
I always ask for the dome light switch that goes in the door jamb. Try checking with some of the online auto parts store catalogs.
Old Dec 24, 2004 | 09:28 AM
1bgredtk's Avatar
1bgredtk
They are called Dome Light Actuator Switches for the door jamb. Junk yards, ebay, some auto parts stores.
Be careful when unplugging your old ones the wire tends to short inside the jamb. You also may want to disconnect the battery as the exposed connectors tend to hit the metal body as you pull the body and the wire out of the hole.
Old Dec 24, 2004 | 01:42 PM
ford390gashog
i just realized the new ones don't have wires on them my old wires rotted out of the back of the switch so i guess i will find the parts at the junkyard
Old Dec 24, 2004 | 01:54 PM
ranger429's Avatar
ranger429
That is correct, they only have a spade conncector on them to hook up to the OE wiring. You can fix your wire with a new piece of 14-16 gauge wire and a blue spade connector to attach to the new door jamb switch.
Old Dec 24, 2004 | 02:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
Some of them have tiny pins in the connector. The wires won't "short out" if they touch metal. All they will do is turn on the dome light.
The circuit runs:
POWER > fuse > dome light > switches > ground
The dome light bulb limits the current in the circuit. The fuse protects the wiring to the dome light fixture.
Old Dec 24, 2004 | 02:24 PM
ranger429's Avatar
ranger429
Torque on the 73-79 F-series they did not use the 2 pin model. Our style was simply a male spade terminal that had a power wire attaching to it and the ground was achieved when it made contact with the door jamb, in order for it to work when you opened the door the spring loaded center would make a contact with power and then turn on the dome light.
The style you are reffering to did not come out till later.
Old Dec 24, 2004 | 02:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
My 1978 has the pin style. I just replaced it a couple of years ago. No spade lugs. It also has OEM wiring as far as I can tell, no splices. That pin style connector is bad compared to the spade lug type. Both switches operate the same. They ground out the dome light circuit.
Old Dec 24, 2004 | 02:42 PM
ranger429's Avatar
ranger429
You are correct Torque, I stand corrected. I must have been thinking of a chebby.
Old Dec 24, 2004 | 03:12 PM
stephenw's Avatar
stephenw
I got a pair from my local Ford dealer within the past year. They are a slightly different style, but are a universal fit, the metal collar around the button depresses permanently according to how much clearance there is between door and frame. It was just plug-n-play.
Old Dec 25, 2004 | 02:55 PM
1bgredtk's Avatar
1bgredtk
Maybe short out was the wrong term. Mine sparked against the body when I pulled them out and then the wire from inside the body shot back in the hole.
LMC has them for $7.95 each I believe.
