Safe Liquid?
Old Dec 23, 2004 | 11:30 AM
wickymustang's Avatar
wickymustang
Safe Liquid?
I am going to change the fluid in my 95 F150 tranny, it has the M5OD. With a little over 86K on the clock will switching to synthetic be asking for leaks or will I be ok? I was hoping to go synthetic to work better in low temps and keep wear to a minimum.
Old Dec 23, 2004 | 01:48 PM
rclarke's Avatar
rclarke
Synthetic Mercon III should work fine.
Old Dec 23, 2004 | 03:33 PM
wickymustang
No need to worry about leaks?
Old Dec 24, 2004 | 05:12 PM
rclarke's Avatar
rclarke
The only leak problem with M5OD is the rubber plugs in the shift rails. I would change them. You could have a seal leak but I wouldn't blame synthetic oil for it.
Old Dec 24, 2004 | 05:42 PM
wickymustang
Alright, that is what I thought. Thanks, if it ever warms up any I will do that on Monday.
