air filter
Old Dec 23, 2004 | 10:28 AM
akbash's Avatar
akbash
Question air filter
Anyone know anything about a improved flow air filter made by Green filters? Alan
Old Dec 23, 2004 | 11:04 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Are you dissatisfied with the stock one?
Old Dec 23, 2004 | 11:24 AM
akbash's Avatar
akbash
Only if I can a better one.
Old Dec 23, 2004 | 01:12 PM
eharman's Avatar
eharman
What makes you think there is a better one?
, EJ
Old Dec 23, 2004 | 01:43 PM
akbash's Avatar
akbash
There may not be a better filter than oem, but I know that if there is ,someone here will know about it.
Old Dec 23, 2004 | 01:47 PM
Maxium4x4's Avatar
Maxium4x4
Your looking for an improvement that isn't there..........stock filters are fine
Old Dec 24, 2004 | 10:15 AM
Canine 582's Avatar
Canine 582
How long will the OEM last under not so dirty conditions?
Old Dec 24, 2004 | 02:03 PM
IB Tim's Avatar
IB Tim
That is tuff to answer ...becasue of conditions....IMO two years...others need to chime in on this one..I am never in the dirt.
Old Dec 24, 2004 | 02:31 PM
jdadamsjr's Avatar
jdadamsjr
It's more a matter of miles and use than time....
Some, like Choctaw Bob, idle for hours on end at a construction site...
I on the other hand drive around new neighborhoods here in North Texus....
Mine lasted about 11 months and 43K miles....
Old Dec 24, 2004 | 03:09 PM
akbash's Avatar
akbash
The Green filter that I referred to said it was washable.
Old Dec 24, 2004 | 07:04 PM
zirius's Avatar
zirius
I think the washables have been found to let more dirt in the the stock one.
Old Dec 24, 2004 | 07:30 PM
akbash's Avatar
akbash
My bulldozer,hydraulic excavator, Int. selfloading scraper operator manuals say wash filter, air dry and reinstall. Some cost over $100.00 each.
Old Dec 25, 2004 | 03:19 AM
jackofalltrades's Avatar
jackofalltrades
Hey Tim, maybe you can help us find the info.
Tim or anyone else. I've searched to no avail. I remember a thread about cold air intakes and stock filter replacements. About a couple months ago.
There was a lengthy post from a FTE member/outfit that actually tested many intakes and filters. Particular emphasis was put on the silicone used on the washable filters and how that affected the sensors in the intake path. There were also some oil analisys results cooresponding to the filters ability to clean, pass/not pass on the silicone, and flow air. I remember that the stock filter actually cleaned the air best, and that it's flow numbers were middle of the road in comparison with many higher end units.
If anyone knows where this thread is, please post the link here. It had some good info in it.
I'm a firm believer in the Zoodad mod. If that small change can make differences, then one would think there's something else that Ford might not quite have engineered to the fullest extent.
Thanx,
Old Dec 25, 2004 | 03:48 PM
Maxium4x4's Avatar
Maxium4x4
The one I have is 2 filters, the larger outside prefilter that is washable, and the inner which is not.
Old Dec 26, 2004 | 10:39 AM
guydiver12's Avatar
guydiver12
What I really want is a direct replacement,reusable,washable type filter. I know the Green filter does that, just don't know anyone who has tried it. They're European in origin, used a lot over there from what I learned on the website. I've used K&N in the past, and they have the rep to back up their products. I know at least one 6.0 owner I have spoken with that loves his Airraid filter system. I do understand that filtration is a very high priority here.....just looking to get the best of both worlds, if that is possible.
