air filter
Old Dec 26, 2004 | 01:55 PM
B Fox's Avatar
B Fox
air filter
Just put an AFE replacement filter and housing in my dads 05. Its washable and a pretty blue color.
Old Dec 26, 2004 | 02:57 PM
Maxium4x4's Avatar
Maxium4x4
The up side is service over the OEM, the down side is people tend to forget and more dirt enters the system from lack of maintaining the wash and oil.
Old Dec 26, 2004 | 09:12 PM
rougerocco's Avatar
rougerocco
my friend has one for his 03 6.0L, I don't care for it... the fit is not as good as some of their other filters( I have 3 other ones). That is what I like about green filter, the fit and finish and the media.
Old Dec 27, 2004 | 09:32 AM
eharman's Avatar
eharman
I would not use the "pretty blue" filter from AFE. I only has four layers of
filter media. That is not enough protection for the turbo. Replace it with the
AFE PG 7 if you must use an aftermarket intake.
,EJ
Old Dec 27, 2004 | 01:11 PM
eharman's Avatar
eharman
,EJ
"I only" should read, "It only". A touch of brain fade, I guess.
, EJ
Old Dec 28, 2004 | 12:08 AM
jdadamsjr's Avatar
jdadamsjr
The real downside is that MY dealer said "No intake upgrades"
and given that the gains have not REALLY been backed up by real world test.... (in fact, some have gone back to the stock intake after putting on aftermarket) I'll stay with the stock one - at least on my truck
Old Dec 28, 2004 | 12:40 AM
Maxium4x4's Avatar
Maxium4x4
I am using the stock intake....but after a statement like that, I would find a nice aftermarket intake "Because I Can" and I own it......
Old Dec 31, 2004 | 10:29 AM
B Fox's Avatar
B Fox
aFe blue filter
,EJ
E mailed aFe and told them about your concern. They told me that for offroad use the 7 would be better but would give up about 10% more airflow.For highway use what my dad will be doing mostly [towing 30ft 5er] she said the blue is the way to go to maximize airflow and make the most power.Also installed SS turbo back exhaust [no cat] and deep sump tranny oil pan.
Old Dec 31, 2004 | 11:39 AM
eharman's Avatar
eharman
With a $40,000 truck, I would rather be safe than sorry. The only blue filter that goes in my truck, the blue filter from the Big Blue Oval.
EJ
Old Dec 31, 2004 | 06:28 PM
SBV45's Avatar
SBV45
The stock filter is made by Donaldson. They are an industrial filter manufacturer that made the 6.0L filter for the military in the first Gulf War. You can't beat it.
You should get 60,000 miles in "normal" service.
The aftermarket filters don't equal the filtration the stock filter gives. The dyno numbers I looked at for K&N, don't show any improvement on performance untill after 2500 rpm. Most of the highway driving I do doesn't get higher than that. Most aftermarkets for the 6.0 I have seen are a variation of the K&N. So why fix something that ain't broke?
Old Dec 31, 2004 | 07:25 PM
Sark's Avatar
Sark
Originally Posted by akbash
There may not be a better filter than oem, but I know that if there is ,someone here will know about it.
Take a look at "Wix" filters, all the boys in the know that I've talked to say "WIX" is the best, other than OEM.
Old Dec 31, 2004 | 07:38 PM
bnmccoy's Avatar
bnmccoy
As SBV45 says the stock filter is made by Donaldson. Check out this web site.
http://www.donaldson.com/en/engine/s...ary/001220.pdf
If there is no vacuum on the tale-tell then you will be hard pressed to convince me that the filter is causing a loss of power.
The stock filter is an excellent filter; I'll stick with it. It flows well and has a very large surface area by design to trap dirt. Ford did good.
Bob
Old Dec 31, 2004 | 08:29 PM
  #28
tn mac's Avatar
tn mac
Stock Filter Does A Great Job
Old Dec 31, 2004 | 10:13 PM
  #29
B Fox's Avatar
B Fox
aFe air filter
I didnt know the electronically controlled direct injectid variable boost turbo 4 valve 6.0 IH was around when George Sr. was at the helm.Probably could have used some of that Donaldson technology on the first Apaches that showed up from what I can recall.K&N doesnt make a replacement for the 6.0 from what I could find.But for sure aFe and Green or Airaid are all after a piece of K&Ns market share with equall or better product.
Old Dec 31, 2004 | 10:21 PM
  #30
tn mac's Avatar
tn mac
just be careful,it is n ot a good idea to have a open element it will void your warranty
