750 carb.
Old Dec 23, 2004 | 09:13 AM
squirrelhunter's Avatar
squirrelhunter
750 carb.
Has anyone run a 750 holley vac sec. on a 400 bored? If not what is the most popular size?
Old Dec 23, 2004 | 10:14 AM
Torque1st's Avatar
Torque1st
Posting Legend
A 600 CFM carb is more than enough.
Old Dec 23, 2004 | 11:12 AM
todd79_351's Avatar
todd79_351
I live in bowling green, home of Holley. Over the last 21 years, I have run several different Holley's on my 79 351. A 750(3310), 600(4776) and a 600 part#(1850). All of them ran ok with a light tan reading on the plugs. But the (1850) is the overall best carb. It starts and idles the best and performs great all around.
Old Dec 24, 2004 | 12:25 AM
Torque1st's Avatar
Torque1st
Posting Legend
A carb that is too big for the engine will be harder to tune, give poorer gas mileage, and cause other driveablity problems.
A good rule of thumb for a street engine is 1.5 x Cubic" = Max carb size CFM.
1.5 x 400 = 600 CFM.
A 600 CFM would be OK for a street engine or mildly built engine. Go slightly smaller for best economy on a street engine daily driver. A 750 would work on a well built motor used for drag racing or mud bogging etc.
Old Dec 24, 2004 | 11:15 AM
todd79_351's Avatar
todd79_351
Most 750's will not run very well on a mild 351/400, but the #3310 will. The first carb I put on mine was a factory replacement for a clevland 4v 600 cfm. It ran fine , but did not make the enging perform like it should. The #3310 made it wake up. I still have it for a backup.
Old Dec 24, 2004 | 02:56 PM
The Shadow's Avatar
The Shadow
Thumbs up
As much as i hate to give away some of my secrets, here goes nuttin'. Ford 400 .030 over, a.k.a. 408. Comp 268dur @.494 lift dual plane intake (pick one) headers, dual 2 1/2" pipes, holley 80508-s 750cfm 4bbl, #64 main jets, red pump cam, (set correctly) vac secondary spring begins opening @1925rpm, full MSD ignition, 12 degrees of advance @800rpm idle (18inches of mercury@manifold port) with vacumm hooked up. Pulls like a turbine, gets awesome mileage! (for what it is) Again, I cannot stress enough the use of rich/lean guages in conjunction with a in-cab vacumm guage. Don't forget patience!!
Old Dec 24, 2004 | 08:56 PM
crack's Avatar
crack
im getting a 2brl 500cfm for 100 bucks....just for my stock 351..will it work ok on it
Old Dec 24, 2004 | 10:27 PM
Torque1st's Avatar
Torque1st
Posting Legend
1.5 x 351 = 526 CFM
Should work fine.
Old Dec 24, 2004 | 11:52 PM
crack's Avatar
crack
sounds good
Old Dec 25, 2004 | 04:05 PM
squirrelhunter
Thanks
Thanks for the info. This site is the best for honest and friendly info. I have access to both a 600 and a 750 just wanted to use correct one. I am about ready for a test ride.
