Dana 60 Vs: 70
Old Dec 23, 2004 | 07:19 AM
LTF250's Avatar
LTF250
Talking Dana 60 Vs: 70
Just Found That My 73 F-350 Scs Has A Dana 70 W/ 4:10 Ratio. Can Annyone Tell Me What The Difference Is Between The Dana 60 And Dana 70?
Old Dec 23, 2004 | 10:01 AM
hawkrod's Avatar
hawkrod
The 70 is bigger. The F350 has a higher load rating than the F250 so it uses a heavier duty axle assembly. I would love to stumble accross a 4.11 70 locally for my 77 1/2 F250 4X4. Hawkrod
Old Dec 23, 2004 | 01:09 PM
ivanribic's Avatar
ivanribic
The D70 is all around bigger. Larger axle tubes, USUALLY a 35 spline 1.5" axle shaft which dwarfs the 30 spline D60 shaft, 10.5" ring gear (I think the D60 is only 9.75"). That's an excellent axle you have there.
Old Dec 26, 2004 | 07:28 PM
78f3504x4's Avatar
78f3504x4
Is this a SRW?
Old Dec 27, 2004 | 07:00 AM
LTF250's Avatar
LTF250
Single Rear Wheel
Old Dec 27, 2004 | 06:44 PM
fordtruck87's Avatar
fordtruck87
yea d60 is 9.75 d70 is 10.25 or 10.50 i just got a dana 135 wonder how big its ring gear is
Old Dec 27, 2004 | 08:46 PM
78f3504x4's Avatar
78f3504x4
Your ring gear is 13.5"
Old Dec 27, 2004 | 09:16 PM
SoCalDesertRider's Avatar
SoCalDesertRider
If I remember correctly, the ring gear on the 135 is around 12". '135' stands for 13,500 lbs, the axle's gross weight rating.
Old Dec 28, 2004 | 06:40 PM
fordtruck87
yea its 13.5 inches i asked wrong question i was wondering weigth it has disc brakes which is bout 200 lbs lighter than drums me and a buddy lifted it no problem i quess about 600
defiantoutlaw
Mar 28, 2014 09:16 AM
fordatic
Mar 6, 2014 08:13 AM
Dirtyweekender77
Nov 10, 2013 07:51 PM
L.TONY F350
Jul 4, 2010 09:08 AM
mustanginca
Feb 9, 2008 06:33 AM
