high start up idle???
Old Dec 23, 2004 | 01:52 AM
mattd17's Avatar
mattd17
Cool high start up idle???
hi, i have a 99 f250 SD with the 5.4. when i start it in the morning, it seems to run a little high to me... around 1500 rpm's at first, and then after about 30-40 seconds it will slowly kick down to about 1200 or so. all and all, it takes about 5 minutes to get down to 700-800 rpm. we have had temps lately around 38-40. when it finally warms up, it seems to have a slightly uneven idle. could this be the idle air control valve going bad?? would that throw a code to turn on the engine light? the light hasd not come on at all. what else could do this..... i recently changed the plugs and the #4 cop due to the known missing problem . but the idle seems off to me. what else could i check before i go and dump 60.00 away on this valve?? thanks !
Old Dec 23, 2004 | 09:10 AM
Phil056's Avatar
Phil056
My '98 Expedition 5.4L does the same thing, but the high idle only lasts about 10 seconds and it goes down to around 1,000 rpm for about another 10 seconds then it goes to around 700. Have you tried cleaning your MAS (mass air flow sensor), throttle body valve? etc...
Old Dec 23, 2004 | 09:39 AM
mattd17's Avatar
mattd17
i will check all that today and see how it works.... thanks !!!
Old Dec 24, 2004 | 11:25 PM
LxMan1's Avatar
LxMan1
The IAC could be sticking. You can try removing it and cleaning it with carb cleaner by spraying it into the two large holes then dumping it out a couple of times.
Old Feb 23, 2005 | 07:16 AM
remia99's Avatar
remia99
Please help a newbie - where is the IAC located? Can you email me a pic? This problem sounds identical to what I see, except that it'll randomly idle high, and punching the throttle will cause it to settle again.
Old Feb 26, 2005 | 05:12 PM
LxMan1's Avatar
LxMan1
It is located just behind the throttlebody on the intake elbow. It is held on my 2 8mm bolts and has a 2 wire plug on it. It is just below the cowl and a little tight to get to.
