Turn Signal, Multi-switch
Old Dec 22, 2004 | 08:58 PM
rangedog's Avatar
rangedog
Bad multi-switch in 98 Explorer, Dealership says that you cannot just replace the multi-switch. They say that I also need to get an adapter cable and wire it in. Is this true and is it easy or hard to do. Thanks.
Old Dec 22, 2004 | 09:23 PM
mvoeller2's Avatar
mvoeller2
I replaced my multifunction switch(if your referring to the turn signal, windshield wiper switch) in my 97 explorer and was never told about any rewiring a cable in. Don't know what they are referring to there. And it is fairly easy to put in, took me about 10 minutes to do.
Old Dec 22, 2004 | 11:42 PM
CobraXP's Avatar
CobraXP
I've never heard anything about an adapter cable?!?!? I've replaced mine before and took about as long as mvoeller did...
Old Dec 23, 2004 | 01:25 PM
Bruker's Avatar
Bruker
I was getting the "buzzing" sound from the turn signal switch when I would flip it to the right turn. I took my switch out, disassembled it, cleaned the contacts with a scotch bright pad, relubed it and it hasn't "buzzed" since. Maybe you could try that first.
Old Dec 24, 2004 | 07:08 AM
rangedog's Avatar
rangedog
Thanks for your imput, I think I will just install the switch and be done with it.
2002 Ex-Suburbanite
Feb 26, 2012 04:30 PM
gp_supercrew
1997 - 2003 F150
Sep 22, 2007 04:25 PM
Falconman
1997 - 2003 F150
May 24, 2005 07:50 PM
dgeist
Feb 23, 2005 11:13 PM
