running hot
Old Dec 22, 2004 | 07:35 PM
james grega's Avatar
james grega
Angry running hot
my 1977 f-150 with a351modified engine is running hot when i get stuck in traffic. i put in a new radiator water pump and thermostat. it runs fine if it keeps moving any ideas?
Old Dec 22, 2004 | 07:47 PM
woodsrider505's Avatar
woodsrider505
how is your fan shroud? also the position of the fan will make a difference. I hope it is a simple fix!
Old Dec 22, 2004 | 08:23 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Enjoy FTE
Old Dec 23, 2004 | 01:35 AM
Torque1st's Avatar
Torque1st
Posting Legend
Typical missing fan shroud or bad fan clutch. When you are going slow or stopped the fan pulls the air thru the radiator. When you are moving fast the movement of the vehicle forces air thru the radiator.
Old Dec 23, 2004 | 07:53 AM
holland501's Avatar
holland501
Something made you replace all that stuff. I'm going to assume that the engine overheated at least once to get your attention. If you have an electrical temp gauge, replace the sender. When these things get real hot it screws them up inside and they read hotter than normal after that. If it's a capillary tube gauge, buy a cheap replacement and take a reading with it to see if there is a difference. They will get damaged also when heated beyond their normal range. Good luck.
Old Dec 23, 2004 | 08:19 PM
Dick Todd's Avatar
Dick Todd
If The Engine Has Been Bored To Or Near Max They Tend To Run Hotter Than Normal.
