98 Explorer Interior Lights
Old Dec 22, 2004 | 03:06 PM
jgrdad's Avatar
jgrdad
Question 98 Explorer Interior Lights
I have a 98 Eddie with a light problem. When I open ANY door, the interior lights do not come on. I turn the dimmer switch to the "on" position and all lights come on . I have also noticed that the illuminated entry does not work either. PLEASE HELP!!!!
Old Dec 22, 2004 | 05:29 PM
87 XLT's Avatar
87 XLT
See if you can swap the interor lamp relay with another identical relay. On a 97 the relay is below the drivers side rear window, probably the same on yours.
The different bulbs are grounded at different locations, so the relay is most likely the problem
Have you got a wiring diagram??
Old Dec 22, 2004 | 07:52 PM
jgrdad's Avatar
jgrdad
No. Will a Haynes manual have it?
Thank you!!!
Old Dec 22, 2004 | 08:55 PM
87 XLT's Avatar
87 XLT
Thank you!!!
What you need is the Ford "electrical & vacuum trobleshooting manual"/EVTM from www.helminc.com For troubleshooting electrical problems this manual is worth it's weight in gold.
But look above the jack storage area, the diagram in the EVTM shows the relay is just below the drivers side rear window.
