I have a 2000 Explorer and live in upstate NY. It has been very cold the last couple of day's. When my wife goes out and starts the Explorer it reves up and the down and quits. It doesn't seem to want to hold the high idle. I have just replaced all 4 O2 sensors because the service engine light came on. After the Explorer warms up about 5 min. it will run great? So can anybody tell me what is causing this to go from 1500 rpm to 0 and so on? Is there a sensor somewhere? Thanks
Bob
My 2000 does the same thing. I've changed the intake gaskets and the MAP sensor with no luck. I'm looking to change the IAC next and hope that fixes my problem. On the main forum page at the top there is a sticky on the IAC that may be very helpful to you. Its also about the easiest thing to check out first.
I have the same problem. When outdoors temp is below about 45 degrees, the car idles very irratically until engine warmed up. Temps in the 20's make it almost impossible to keep running - starts and revs way up, then dies over and over. If you can get going, it will keep running (poorly), then when warms up it is fine.
I have replaced the IAC with no improvement. On possibly related note, the heating system will only give out max hot air (except in Max airconditioning or Auto) regardless of the temp setting I select - but I haven't been able to hear/identify a vacuum leak. Any suggestions?
I had the same problem with my 98 4.0 SOCH. It would never stay running when cold.I changed the intake manifold o-rings both the lower and upper. It starts just fine now since I did it.
I have the exact same problem also. My question is how bad does the fuel milage go when the weather goes cold like this with this problem? I have about a 20% in fuel milage in the cold weather and can justify spending the money to fix the starting problem if it fixes the milage problem too.
it does help out with the fuel milage because you are not holding down the gas to keep it running when you first start it. my gas milage increased by about 4 more miles to the gallon.
