any problems with 2002 ford rangers?
Old Dec 22, 2004 | 02:11 PM
5plusfordtrucks's Avatar
5plusfordtrucks
Question any problems with 2002 ford rangers?
I recently bought a pre-owned (used) 2002, Ford, ranger, XLT, 4X4, with the 4.0L(62,000 miles). I have not had any problems with my truck, but I would like to know if anyone has had any out of the 2001-03 that I may need to look for. The biggest problem that I have experinced is that the driver side window seems like it is always off track. Other than that I love it!, Please let me know, thanks!
Old Dec 22, 2004 | 03:00 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum. The members in this forum are very knowledgeable about these trucks, they will be by.....hang around someone will help
Congratulations on the truck
Enjoy FTE
Old Dec 22, 2004 | 03:18 PM
el conquistador's Avatar
el conquistador
which tranny?
Old Dec 22, 2004 | 03:39 PM
bdee's Avatar
bdee
my 02 Edge power windows seem to "skip" when rolling down, i took it to the dealer, they resolved it temporarily, but it always seems to go back to skipping/jumping when rolling down.
Old Dec 22, 2004 | 03:52 PM
gecko03's Avatar
gecko03
I have an '02 Ranger XLT 4x4 4.0L too, I only got 43100 on it though. so far I have had the air bag light come on, code 46 "drivers side pretensor circuit high or low." Also my drivers side power window doesn't work at all, dealers supposed to fix it next tuesday... although it could just be frozen shut.
Old Dec 25, 2004 | 10:26 AM
5plusfordtrucks
sounds like the window thing is a common problem, my airbag light has also come on a couple of times... as well, eveytime I plug the pigtale of my boat up, my check engine light comes on... any idea why?... by the way, it is the Auto w/OD tranny
Old Dec 25, 2004 | 12:51 PM
miltoney's Avatar
miltoney
2002 4x4 4.0L 30,000 miles
been in the shop 4 times already...
1. check engine light, egr valve
2. battery light, excessive corrosion, replaced leaking battery
3. 4WD would not engage, bad 4X4 Control Module
4. Rear window leaking
And what is with the tires on this thing!!! I can't believe how noisy these things get, and yes I do rotate them.
But believe it or not, I still like my truck
Old Dec 25, 2004 | 02:02 PM
5plusfordtrucks
If you BFgoodwrech Long Trail's, it is the way that they are made. I talked with a guy at the place I bought my tires, (I did purchase a new set) and he said that everyone who buys them says they have the same problem with them. The way I see it is I am driving a truck, and other than the noise, I like everything else about them, so I can live with it. Otherwise you start to sacrifice the traction for road comfort, and I need to be able to go off road as well as on road.
Old Dec 25, 2004 | 06:20 PM
miltoney's Avatar
miltoney
mine are the stock goodyear wranglers, which from what I have read, are junk...oh well one more year and I can get new ones.
Old Dec 26, 2004 | 09:56 PM
5plusfordtrucks
I would suggest the BFgoodrich Long Trail T/A, they hum a little, but they have great wear and traction. To tell you the truth, I have never had a goodyear tire that I like, and you couldn't give me a set to put on any of my trucks! ("The most expensive tires in the world have Goodyear written all over them")
Old Dec 27, 2004 | 08:25 AM
agoldberg03's Avatar
agoldberg03
I have a 2002 XLT 4x4 4dr 4.0. The only problem I have had since new was the goodyear tires. I replaced them at 20K. They wore unevenly (and yes I did rotate as directed by the manual). They had uneven wear around the edges. Both the dealership and a tire dealer told me that the Goodyears that Ford puts on at the factory are lower quality than the exact model replacements you get (from Ford or Goodyear).
Old Dec 27, 2004 | 10:53 AM
LILBLUE04FX4L2's Avatar
LILBLUE04FX4L2
2002 FX4 Rangers had a recall on the rear end
Old Dec 27, 2004 | 04:40 PM
PW01's Avatar
PW01
Look for the timing chain "rattle".
Old Dec 27, 2004 | 11:20 PM
5plusfordtrucks
I Have been hearing something that sounds like chatter... is that the timing chain? is there something I need to do? and what recall does ford have on the rear end? I have not recieved any recall notices, any information would be greatly appreciated, THank You!
Old Dec 27, 2004 | 11:31 PM
RoushRacen's Avatar
RoushRacen
Theres a new repair for the chain Rattle concern. It replaces the chain, gears and chain guides that go from the crank to the balance shaft. Its not the chain from the cams to the balance shaft this time. Its not a recall now but theres a TSB out for a "Rattle noise at 45mph". Far as the window chatter deal, remove your door trim panal to gain access to the window guide. You'll see wear marks on this guide, ford has an updated guide that takes care of this problem. I replace mine but I also lubed the guide with some anti-seize. Its worked fine for the last 3 years now.
