Front spring/airbag question
Old Dec 21, 2004 | 10:14 PM
pdkloste's Avatar
pdkloste
My 97 4x4 front springs have seemed to sag about 2 inches from the original arch.... from what I have seen, this seems to be a normal "problem" for the earlier PSD's.
I was looking at putting a 4 inch lift on, but have decided that I want the option of using a snow blade if I need to, and not have to get a pair of drywall stilts for the wife to get into the truck.
Any of you use front airbags or know of a good vendor for a spring kit?
Pros and cons of bags? Tips for putting new springs in?
Been putting this off for quite a while and still need help deciding what to do.
Thanks for the help.
Old Dec 21, 2004 | 10:31 PM
mech2161's Avatar
mech2161
Does your truck have independent front suspension?
Old Dec 21, 2004 | 10:44 PM
pdkloste's Avatar
pdkloste
I don't believe that it does. I haven't paid any attention to IFS setups on the Fords, but my front end is attached to the leaf springs with no torsion bars. I bet you can't tell that I am not a suspension wizard!
Old Dec 21, 2004 | 10:48 PM
mech2161's Avatar
mech2161
Is there a pivot point at the center of the axle near the diff?
Old Dec 21, 2004 | 10:52 PM
pdkloste's Avatar
pdkloste
Yes, there is... hadn't really noticed it before!
Old Dec 21, 2004 | 10:53 PM
mech2161's Avatar
mech2161
When you look at your front tires do they look like this //----\\ ?
Old Dec 21, 2004 | 10:59 PM
pdkloste's Avatar
pdkloste
No, just put new rubber on about 6 months ago, minor alignment problems were corrected then along w/new shocks. Tires are wearing evenly. This pivot point... does it indicate IFS?
Old Dec 21, 2004 | 11:09 PM
mech2161's Avatar
mech2161
When the springs start to sag the tires will lean in at the top beyond the point an alignment will correct. Air bags are not an option for the IFS. The answer is up to you, lift or no lift.
Old Dec 21, 2004 | 11:15 PM
pdkloste's Avatar
pdkloste
Thanks mech2161, I appreciate your input and informing me that I have IFS on my truck. I thought it was a solid front end!
I was under the impression that most IFS had front coil springs w/torsion bars.
Again, thanks.
