Squeeky Turbo when cold
Old Dec 21, 2004 | 10:14 PM
kawika's Avatar
kawika
2001 F250 PSD CC 4x4 Lariat
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Starting to get cold here in IL. Since I’ve changed out my air filter, I hear my turbo much more. Recently, I’ve noticed that after a few minutes of warm up in the morning (Block heater plugged in a few hours before starting), when starting out for the first time. I am hearing a squeak starting at about 1500 rpm’s when pulling out and if I stop the truck, the squeak slowly stops. At first I thought that it was my brakes, but I stopped fast one time and I still heard the squeaking (listen, this is what it sounds like over the internet, some fast Squeaks, slower squeaks, squeeeak, squeeeeak, then stops), will not hear it again until about 1500 rpm's, let off of the gas, squeaks taper down and stops after a few seconds (5 to 10 seconds). After a few minutes of driving and stopping, I can not hear it any more until the next time I start up my truck (cold). Should I start to get worried? Just wondering if I have to start saving up for a new one. I have too many things on my wish list to have to replace a turbo.
Old Dec 21, 2004 | 10:34 PM
mech2161's Avatar
mech2161
Remove the air intake tube and check the turbo. Spin the shaft, check for noise and end play.
Old Dec 21, 2004 | 10:46 PM
kawika's Avatar
kawika
Well, I guess I have something to do over the Holidays.
mech2161,
How much end play should I expect when it is cold? Warm? Also how much resistance will there be when I try to turn the shaft of the turbo by hand? Just trying to get as much info before jumping in, than having a lot of questions after I finish.
Thanks for posting your responses.
Dave
Old Dec 21, 2004 | 10:49 PM
kawika's Avatar
kawika
mech2161,
Just noticed your from Morgantown. I lived up at Kingwood and worked at Etam. Ha, small world.
Dave
Old Dec 21, 2004 | 10:51 PM
mech2161's Avatar
mech2161
No end play hot or cold. Little resistance when you spin it and should continue to spin for a short time, a couple revolutions.
bronzeback
Dec 10, 2008 04:09 PM
michaelgr
Bronco II
Jan 10, 2008 02:53 PM
TN_F250
16
Dec 6, 2007 08:31 AM
Technocrsr
Jun 6, 2007 08:27 PM
Dominater
Apr 27, 2005 04:44 PM
