Bronco II Ford Bronco II
Poor Acceleration
Old Dec 21, 2004 | 07:29 PM
slimbronco's Avatar
slimbronco
Poor Acceleration
Ok I have a 84 B2 with the 2.8L v6 and the 2100 Motorcraft carb. I went out mudding again and I sucked up a lot of water. I let the carb dry out and ran some carb cleaner through it and everything seemed ok until I started heading home I had really bad acceleration and once up to speed I had a hard time keeping the bronco up to speed. I nursed it home and let it sit until the next morning I went out and started it up and still ad the same problem so i started to check the fuel filter and fuel pressure and both looked good I also replaced the air filter due to the mud I was extremely clogged. I let the bronco run for a while and drove it around and eveything seemed to be working much better I got in a couple hours later and I had the same thing happen but this time it didn't go away after I let it sit. Once the bronco gets past 15mph it starts to accelerate like it should but up until then it's almost like I'm not even giving it gas. Also I still have a hard time keeping it up to speed. It idles fine as well. I'm thinkging it's a dirty carb and I just need to get a repair kit and clean the carb but I thought I would see if any one had some ideas.
Old Dec 24, 2004 | 08:25 PM
DJ_FX's Avatar
DJ_FX
nobody has posted nething so i'll throw in my 2cents... try checking the oxygen sensor and make shure that the catalitic converter is ok (one sign of a clog is that if u let it run for a bit untill it gets nice and warm, then look at the exaust pipe entering it and itz glowing red, it is clogged). my dad's mini van had kind of a simmiler problem, it would idle, but as soon as u tried 2 do anything it almost didnt go. we never tried to push it up to (whats 15mph in km lol) well, we never tried to get up to 15km/h.
hope this helps and good luck
Old Dec 24, 2004 | 09:03 PM
slimbronco's Avatar
slimbronco
thanks I will take a look at that tomorrow. I had kind of the same problem when I first bought the B2 and it drove just fince after putting some new gas and carb cleaner in it the more I drove it the better it got. I put some fuel additive carb cleaner in it yesterday to see if it would help and it did to a point. I'm waiting for a warm day or a day when the base auto shop is open to get in and clean the carb good.
Old Dec 27, 2004 | 11:32 PM
RomerB2's Avatar
RomerB2
Is it possible the distributor got water inside the cap too? I would check that too.
Old Dec 28, 2004 | 10:31 AM
slimbronco's Avatar
slimbronco
I checked the distributor first thing after it died and the inside was dry not a drop of water in it kind of wierd if you ask me!
Old Dec 30, 2004 | 12:48 AM
RomerB2's Avatar
RomerB2
yea i'd say so
Old Dec 30, 2004 | 06:21 AM
Icicle's Avatar
Icicle
someone correct me if Im wrong, but an 84 wouldnt have one.
Old Dec 30, 2004 | 06:29 AM
RomerB2's Avatar
RomerB2
I thought all the B2's did, and they all have cats too. I'm not 100% sure though on the o2 sensor.
Old Dec 30, 2004 | 09:41 AM
slimbronco's Avatar
slimbronco
yes my B2 has a o2 sensor I changed that in october
Old Dec 30, 2004 | 02:46 PM
Icicle's Avatar
Icicle
yes I just learned they have feedback carbs and computers......yuck
Old Dec 30, 2004 | 03:08 PM
DJ_FX's Avatar
DJ_FX
it was just a suggestion, oldest vehicle ive dealt with is the 86B2 i just bought on the 16th, and i assumed it had an O2 sensor seeing that pretty much everything dose now.
Old Dec 30, 2004 | 03:16 PM
slimbronco's Avatar
slimbronco
Thanks for your suggestion DJ FX every once in a while some one will think of something that no one else will! I think the problem is the Distributor cap is cracked! I just ordered a new one we will see soon enough
Old Dec 30, 2004 | 10:27 PM
Icicle's Avatar
Icicle
And a good suggestion, Im just opening my mouth when I shouldn't be, I just assumed based on age it didnt have one, I just learned that these had feedback carbs, so its quite possible it does I should learn to keep my mouth shut I suppose.
Old Dec 31, 2004 | 12:08 AM
DJ_FX's Avatar
DJ_FX
lol Icicle... although it is a good skill to learn especially for talkin to the ladies... (lost count of how many times i should have shut it) lol
Old Jan 3, 2005 | 10:07 PM
slimbronco's Avatar
slimbronco
hey guys thanks for all the suggestions the problem seems to be clearing up on it's own I drove it around today for a while and everything worked much better then it has in a while mabye I was a little to rough on it when I was out offroading with some guy I work with trying to keep up with the big boys! I might not have my B2 much longer though seems that a guy i work with need a cheap car to get him back and forth from work and to the commisary so I made him a deal looks like one more month with my little B2
JohnBOV43159
53
Feb 7, 2014 11:11 AM
SteveJH
Sep 1, 2013 10:32 PM
RANGER589
42
May 19, 2011 12:08 PM
F350moneypit
Oct 24, 2010 02:04 PM
the_fitter
Jul 2, 2009 06:40 PM
