ratio rockers.......
Old Dec 21, 2004 | 08:51 AM
460me's Avatar
460me
They say the stock ratio is 1:75,I'am looking to use 1:85.This is for a 79 460 f250 2wd
Any thoughts.
I'll be pulling the motor soon and while it's out might as well try to get some more out of it.My goal is torque as I use it for towing.Other things to put in,straight timimg gears and headers.
Old Dec 21, 2004 | 01:11 PM
chillyF250's Avatar
chillyF250
Stock ratio is 1.73:1
I believe you can get 1.8:1, but they'll be some type of aftermarket rocker with a minimum price of around $200 for anything decent. I'm not sure the cost would match the performance gain.
Old Dec 21, 2004 | 02:59 PM
460me's Avatar
460me
Thanks for the reply.I quess I'll keep it simple,I'll go with the headers,chain and some sort of cam with better torque.Any suggestions on the cam?
Old Dec 21, 2004 | 04:35 PM
Brad Johnson's Avatar
Brad Johnson
The Comp Cams 255DEH is an excellent choice. I think Crane also makes a similar grind, though I've never used it. The 255DEH seems to work really well with the mild bolt-on mods like you're planning. Anything more quickly becomes counterproductive as the stock heads can't breath well enough to support the cam. Don't be suprised if your fuel economy actually improves a small bit (if you keep your foot out of it).
Brad
Old Dec 22, 2004 | 09:58 AM
460me's Avatar
460me
Thanks for the info.
