A4LD Problems
Old Dec 21, 2004 | 01:45 AM
tiggerndome's Avatar
tiggerndome
Question A4LD Problems
I have a 94 explorer 4.0 a4ld trany...the trany just quit pulling,I drove it,parked it,went back to go,starteded it,shifted into gear and nothing...... you can fell it shift but it tachs up and dont pick up to start moving untill about 6 grand and then it will barely move...this is the same for rev. as well,........I've seen foward gears go and have rev. or rev. go and have foward,but never both at once...can that happen?...any ideas?...I checked fluid its fine the filter had just been changed a few weeks ago...I will be thankful for any help on this because it's drove me crazy..I'm just short of pulling it and rebuilding the whole thing to solve the problem....oh and readers do have a nice day and and happy holiday
Old Dec 21, 2004 | 07:10 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum. The members in this forum are very knowledgeable about these trucks, they will be by..... and help you with your question.
Good luck with your problems.
Enjoy FTE
Old Dec 21, 2004 | 10:58 AM
mrshorty's Avatar
mrshorty
Not an expert on this one, but I think that could be a symptom of a bad low/reverse servo seal/o-ring, which does have a history of failure. If it is this o-ring, it's pretty easy to get to -- 4 bolts and a gasket beyond replacing the trans filter, which you said you've already done, so I don't think you'd have any trouble with this. Hopefully someone with a little more experience with this particular problem can step forward to help us know if this is your problem.
Old Dec 26, 2004 | 10:23 AM
bobs 93 X's Avatar
bobs 93 X
really interested in the answer to this one also. mine is doing the same thing. symptoms are: driving along and go to pass someone after slowing down a bit, the transmission feels like it slips into neutral. let up on the gas and push again and it my run all right. stopped at an intersection yesterday and went to take off and nothing. no reverse no forward. revved engine to 3500-4000 and vehicle started to creep fwd. was able to get it to about 15 mph. limping home, I then stopped at another intersection and when I took off again it started out the same way(high revs) then seemed to catch and ran all right the rest of the way home. any ideas?
Old Dec 28, 2004 | 03:43 PM
bobs 93 X's Avatar
bobs 93 X
update to transmission woes. was just told by aamco that the transmission is toast. can't salvage anything can forget rebuilding it. they will install a re-manufactured one for $2386 merry christmas and happy new year
bob
Old Dec 28, 2004 | 04:24 PM
marragtop's Avatar
marragtop
I wouldn't expect AAmco to say anything different. Not a slam on them, because they don't want any comebacks. I suggest waiting for additional replies here, and trying something much cheaper.
bchitwood73
Jan 30, 2005 09:40 PM
racingdeathwish
Dec 21, 2003 12:25 AM
racingdeathwish
Dec 19, 2003 10:23 AM
tolvibman
Jan 26, 2002 11:36 AM
tolvibman
Dec 31, 2001 11:19 AM
