head gaskets
Old Dec 20, 2004 | 07:38 PM
4x4man514's Avatar
4x4man514
head gaskets
my 89 is going to need at tyhe minimum head gaskets.i wont know if the heads are ok til i have them magna-fluxed.heres my question.is there a particular hi-performance aftermarket head gasket i should use?i intend on eventually putting a turbo on it.maybe even upgrading some more.i figured if i would need a hi-po gasket then that i would go ahead and put one in while i was in there.thanks for the advice!kevin.
Old Dec 20, 2004 | 08:04 PM
ditto's Avatar
ditto
the stock engine was made to handle a turbo, it kinda sucks that ford didn't put a turbo on the engine it would have help so much. i'm guessing that it's a 6.9 right?
Old Dec 20, 2004 | 10:17 PM
Dave Sponaugle's Avatar
Dave Sponaugle
An 89 had a 7.3.
The head bolt torque is higher for the turbo engine, gaskets are the same.
Off the top of my head the NA motor is 90 ft lbs while the turo model is 110 ft lbs.
Old Dec 20, 2004 | 10:23 PM
Dave Sponaugle
Sorry for the double post
Old Dec 20, 2004 | 10:28 PM
PLC7.3's Avatar
PLC7.3
I used Fel Pro gaskets they are turbo quality.........6.9 and 7.3
Cut and paste this into an Explorer..... http://www.fel-progaskets.com/
Old Dec 21, 2004 | 04:31 AM
4x4man514's Avatar
4x4man514
it wont hurt to tighten a non-turbo motor to turbo specs,will it?
Old Dec 21, 2004 | 01:46 PM
ditto's Avatar
ditto
7.3, I stand corrected
Old Dec 21, 2004 | 09:44 PM
PLC7.3's Avatar
PLC7.3
4X4 ....Felpro states the max for 7.3 ........
88 to 90 is 65-90-100
91-94 non turbo is 65-90-110 and 110 again "Special sequence"
However point to remember there are two different torque specs....Ford does it there way to preserve the engine parts, Fel Pro does not want their gaskets to leak, so you have to balance the numbers to who you trust.
