clunk
Old Dec 20, 2004 | 06:55 PM
ford390gashog's Avatar
ford390gashog
clunk
when ever the expy goes from park to reverse it clunks into reverse is that normal almost like a loud snap
Old Dec 20, 2004 | 07:03 PM
the4by4freek's Avatar
the4by4freek
Sounds like you got a bad U joint. If you crawl under the truck and look at the driveshaft you should be able to see if it's bad by turning the driveshaft or should I say, try to turn the driveshaft. If you got a bad joint you will see it move.
Old Dec 20, 2004 | 08:41 PM
ford390gashog
i will climb under there and check it out
Old Dec 20, 2004 | 08:54 PM
ford390gashog
i tried to turn it and its solid so i don't think it is the u joint what else could cause this
Old Dec 21, 2004 | 06:57 PM
the4by4freek
When is the last time you did the brakes on it? It could be the backlash from your differential. The rear brakes might not be grabbing like they should and putting a load on the axle when going into reverse. Another way to check this is to drive down the road an give it gas quickly and see if it does it again. It might be somthing tranny related.
Old Dec 21, 2004 | 09:50 PM
ford390gashog
the brakes have about 18,000 miles on them
Old Apr 11, 2005 | 11:49 AM
great white's Avatar
great white
ford390gashog, did you ever solve this problem? I am fighting something very similar to this.
Old Apr 27, 2005 | 06:27 PM
AxleEngineer's Avatar
AxleEngineer
clunk
If you have a 2003 or newer (IRS rear axle) check you torque arm bolts. Make sure they are tight.
