timing ??S
Old Dec 20, 2004 | 01:20 PM
smoke n tires's Avatar
smoke n tires
timing ??S
i set my timing at about 12-13 degrees on my 78 460 and when i go down hills off the gas it pops out the exhaust. i do have some exhaust leaks, but when i had the timing set more advanced it didnt do it. i like how the truck runs other wise. can the timing cause this if its just a few degrees retarded ? its got a new pre 70s chain so the cam is straight up. should the base timing be set at factory specs even with the cam advanced?
