Sponsored by: Real Truck
Oil Heaters
Old Dec 20, 2004 | 01:07 PM
birddog16's Avatar
birddog16
Oil Heaters
I was looking thru JCWhitney and found 2 oil heaters that interest me and was wondering if anyone had expernce with them. 1st is the type that glues to the bottom of the oil pan ( not sure if it would hold up off road) 2nd is a magnetic one. thanks for your help.
Old Dec 20, 2004 | 01:28 PM
ripo59's Avatar
ripo59
I've always used the "glue" on type. I use silicone on the pad heaters and you will have to use a scraper if you hope to remove it in the future. They should do the job. Good luck.
Old Dec 20, 2004 | 01:31 PM
birddog16's Avatar
birddog16
Have you ever had a problem with the glue on one falling or being ripped off?
Old Dec 20, 2004 | 01:46 PM
LilBlackCoupe's Avatar
LilBlackCoupe
I don't see how it could get ripped off.
Old Dec 20, 2004 | 01:52 PM
birddog16's Avatar
birddog16
Take a drive thru a picked corn field some time. corn stalks have been know to punch holes in the oil pan. also the trips in the woods cutting firewood have had things jump up and it parts under there.unfortunatly ford doesnt have a oil pan skid plate in the FX4 packages.
Old Dec 20, 2004 | 02:01 PM
ripo59's Avatar
ripo59
Anything is possible I guess, but short of punching a hole through your oil pan, I think your best bet is the stick on pad. Nothing is bullet proof.
Old Dec 20, 2004 | 02:03 PM
birddog16's Avatar
birddog16
thanks .. sorry about that last post didn't mean to come off like a smart *** just some things I have had happen in the past.
Old Dec 20, 2004 | 03:40 PM
ripo59's Avatar
ripo59
No problem. Hopefully the weather will stay warm and you won't even need to use your heater.
Old Dec 20, 2004 | 03:42 PM
birddog16's Avatar
birddog16
well winter is here it was 2 this morning and supposed to be 0 tomorrow. but I wouldn't trade it for the guys I have read about on here from alaska @ -50.
Old Dec 20, 2004 | 04:01 PM
mlb4966's Avatar
mlb4966
It's just 50 more degrees. Anyway go with the glue on. Also consider one for your tranny.
Old Dec 20, 2004 | 04:08 PM
birddog16's Avatar
birddog16
thanks for the advice I never thought of having one on the tranny. I have a auto but I believe the manuals have atf in them also do the heaters really help them since the have that thin of fluid in them?
Old Dec 22, 2004 | 11:25 PM
mlb4966's Avatar
mlb4966
Some places were it get really cold it helps. I usually do not have that problem. I have (2) 150-watt heaters on my oil pan (one on each side of the oil plug) and only plug them in if it is below zero. They dont get used that much were I live. Check out the tech folder under 6.0 very cold and Twin Triton has a good post on very cold weather. I beleive they even put them on their differental.
JHoffman93
Nov 14, 2013 09:50 PM
mdpilot
1997 - 2003 F150
Dec 21, 2010 11:03 AM
NoHeart2
Oct 28, 2009 01:13 PM
conkl
Oct 3, 2009 12:57 PM
unioncreek
Garage & Workshop
Jan 7, 2003 08:41 AM
