no 4x4
Old Aug 3, 2000 | 06:22 PM
cale's Avatar
cale
no 4x4
I have a '94 Ranger extended cab that won't go into 4wd, I think it's the actuator but I could be wrong. Any help would be apreiceated.
Old Aug 3, 2000 | 07:23 PM
mauzer1's Avatar
mauzer1
no 4x4
Ford has a problem with their t-case shift motors try having some one pressing the button while you get under the truck and tap on the shift motor it will probably start working. You should replace it you can also try taking the motor off and removing the back circle plate there will be @ 5 prongs riding on a copper disc bend the prongs up slightly so they ride good against the copper plate smear dielectric grease on the disc then put it back together. I have done this it works in some cases. Good Luck
Old Aug 6, 2000 | 02:18 PM
GregR's Avatar
GregR
no 4x4
gwh1bass
May 9, 2017 07:51 PM
ooseven
1997 - 2003 F150
Jan 10, 2017 12:48 AM
Slapshottr
Dec 21, 2016 05:52 AM
Welder7018
24
Aug 9, 2015 09:06 PM
goodtobeeme
1997 - 2003 F150
Dec 28, 2010 05:44 PM
