Stock 300 cam specs
Old Dec 19, 2004 | 11:22 PM
1982fordf100's Avatar
1982fordf100
Stock 300 cam specs
Anyone know the lift, duration, etc.. for a stock cam in a 82 F100. Im back to work and I really want to rebuild the engine in my truck in the spring. Im looking at Comp Cams either 260H or 268H. Im not sure yet which one I want to use. For a rebuild with these parts would $2000 sound about right?
Here's a list of parts I want to use or do to it:
1. Offenhauser Dual Plane Intake
2. EFI manifolds
3. Holley 390cfm carb
4. Mild port & polish on head
5. Comp Cams 260H/268H cam
I'd like 200 Hp and 320 ft.lbs of torque at the flywheel.
Old Dec 20, 2004 | 12:59 PM
Silver Streak's Avatar
Silver Streak
The stock cam is 0.250 lobe lift, the adv. duration is around 255 and the duration @ 0.050 is around 195.
Either of the cams you listed would be great. If you are more concerned with low end I'd go with the 260, if you are willing to sacrifice a little low end to gain more top end and a few hundred extra rpm go with the 268.
Old Dec 20, 2004 | 05:42 PM
jwtaylor's Avatar
jwtaylor
FWIW, there are a few that feel the isky supercam 256 or 262 would make a good torque/performance cam.
If you noticed Col Flashmans build, hes supposedly made 300hp/400tq with an off the shelf mellings cam...thats impressive IMO, after looking at the hp and tq peak though, its a pretty fair assumption that the heads were ported very well.
Old Dec 21, 2004 | 10:13 PM
1982fordf100
I followed the build up of Col Flashmans 300, a very nice one it is. Im just looking for a mild 300. Right now my 82 F100 has 313,000+ miles and you can hear all the ticks and other noises it makes. Plus it lacks some low end when you first let the clutch out. Thanks for the info guys.
James Clayton
Apr 17, 2016 08:14 PM
68cabby
Oct 25, 2012 12:14 AM
tjthegreat
Sep 9, 2008 08:20 PM
powderspecial600_98
Jan 31, 2006 08:13 PM
Charles-65F350
May 14, 2000 06:08 PM
