code reading
Old Dec 19, 2004 | 08:47 PM
harold j's Avatar
harold j
code reading
1997 ranger bad gas mileage how do i read codes 2.3 engine
Old Dec 19, 2004 | 09:28 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
'96+ Fords are OBD-II equipped which means you have to have use a scanner to pull the codes. Places like Autozone will do it for free.
Regarding bad gas mileage, how many miles since the last tune-up?
Old Dec 19, 2004 | 09:32 PM
harold j's Avatar
harold j
the mileage started after mechanic changed thermostat and truck does not warm up as quick eventually it warms as before thermostat change on guage
Old Dec 19, 2004 | 09:43 PM
Rockledge's Avatar
Rockledge
The colder an engine is, the more fuel it needs (generally speaking). If your engine isn't warming up properly, it will need and burn more fuel over the long run.
Why was the T-stat replaced? Some of them work better than others.
