Transmission ID Help!!
Old Dec 19, 2004 | 05:14 PM
ktlspop's Avatar
ktlspop
I need to put a clutch in my 89 F-150 4X4 and haven't figured out which 5 speed trans I have. How do you tell the difference between the Mazda and the ZF transmissions?
The only ID tag I can find reads E9TA BA 645552. Does this mean anything to anybody?
Thanks.
Old Dec 19, 2004 | 07:02 PM
WRECKTEC's Avatar
WRECKTEC
I have an 89 F-150 4X4 with a 5 speed. The bigger writing on the tag of mine says E9TA BA and it has the Mazda M5OD. While you have the tranny out, it would be a good idea to replace the 3 rubber plugs on the back of the shift cover. Hope this is helpful.
Old Dec 19, 2004 | 09:03 PM
ktlspop's Avatar
ktlspop
Thanks. Where are those rubber plugs? Where do I get replacements?
Old Dec 19, 2004 | 09:31 PM
WRECKTEC's Avatar
WRECKTEC
The plugs are on the back side of the shift cover on the top of the trans. The rubber plugs are a dealer-only item. There are several posts on this forum about about this subject. I followed the advice of a couple of local tranny shops and they both said not to remove the top cover when replacing the rubber plugs. They went in a little hard, but it worked fine. They also recommended to put 'em in dry. There is also a tech article on replacing the plugs in the tech section.
greenmachine86
Feb 15, 2017 11:30 PM
jes775
Sep 23, 2016 12:45 PM
green_95
Feb 14, 2016 09:04 PM
dyoungen
Feb 22, 2012 08:28 AM
Jermafenser
Oct 1, 2009 04:42 PM
