97 explorer eb sub woofer not working
Old Dec 19, 2004 | 02:55 PM
bedoe's Avatar
bedoe
can anyone suggest somthing?
Old Dec 19, 2004 | 03:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum. The members in this forum are very knowledgeable about these trucks, they will be by..... and help you with your question.
Good luck!~.
Enjoy FTE
Old Dec 19, 2004 | 08:45 PM
bedoe's Avatar
bedoe
please help!
Old Dec 20, 2004 | 07:10 AM
IB Tim's Avatar
IB Tim
Hang on, this time of the year and on weekends it can be a bit slow on the forum.
Monday night has more traffic.....check back.
Old Dec 20, 2004 | 08:07 AM
bedoe's Avatar
bedoe
thanks, looking forward to some good advice from other owners with similar problem. this site rocks, i have learned so much in the past two days.
Old Dec 21, 2004 | 07:48 AM
bedoe's Avatar
bedoe
o.k. I went to the local stereo shop and they tested the woofer and it is bad, they dont have and there are no aftermarket manufactures making a replacement for it.
I dont want to purchase from ford directly ($90.00) so I am looking for suggestions.
Thanks.
Old Dec 22, 2004 | 06:47 AM
spb's Avatar
spb
I have a '98 Eddie Bauer and the dealer told me the replacement speaker came as an assembly only. This assembly included the speaker and amplifier mounted in the plastic housing for the bargain price of....$278.00. I went down to the local flea market and bought a good quality after market 8" sub-woofer. The depth of the new speaker required the cutting away of the rear portion of the plastic housing to allow room for the speaker and the 8 screws that mount the speaker on the front of the housing were sufficient for support of the speaker. The sound is much richer bass and the cost of the speaker was like $40.00. There are many different brands of 8" sub-woofers although you may have to order that particular size, and most have the same eight screw holes on the face of the speaker as the O.E.M. speaker.
Hope this helps,
Steve
Old Dec 22, 2004 | 10:04 AM
bedoe's Avatar
bedoe
thanks steve, unfortunatly for me the 97s and older had a 6.5in speaker so making the 8in fit would require a bit more modifcation than i am willing to perform.
anyone know where i can get the 6.5 besides the dealer?
thanks
Old Jan 4, 2005 | 09:35 AM
dehrd's Avatar
dehrd
Subwoofer replacement
I have a '91 EB Explorer with a working subwoofer and a '97 Mountaineer with a nonworking subwoofer. I think I can switch the two but I can't figure out how to remove the subwoofer cover in the rear cargo area on the passenger side. Any help would be greatly appreciated. Thanks!!!
Old Jan 4, 2005 | 06:03 PM
95EXPLODER's Avatar
95EXPLODER
Remove the whole rear plastic quarter panel.
Old Jan 5, 2005 | 08:15 AM
bedoe's Avatar
bedoe
sub
not necessary to remove the whole panel, just pry off the mesh screen and there are four screws under the foam ring. i found a woofer from etronics on the web for $10.00 plus shipping and it works perfect!
Old Jan 5, 2005 | 08:22 AM
95EXPLODER's Avatar
95EXPLODER
Yea you can pry it off but its gonna break those connectors not meant to be pryed off. But its your vehical might as well just duct tape it back on while your at it.
Old Jan 5, 2005 | 07:35 PM
PrtclMn001's Avatar
PrtclMn001
really? I've removed the screen from my factor subwoofer quite a few times with no problems...
Old Jan 7, 2005 | 12:49 PM
bedoe's Avatar
bedoe
there are no tabs on the mesh screen, you maybe thinking of the plastic insert around the mesh screen. so save the duct tape for a real job.
