Please help!
Old Dec 19, 2004 | 01:55 PM
ranger894x4's Avatar
ranger894x4
Please help!
Hi, sorry in kind of a hurry tried to search but not having any luck. My dad has a 89 ranger 4x4 ext.cab V-6 auto. He's tring to replace the U-joints in the front axle, problem is there not wanting to come out. Anything special he needs to do to get them out? Thanks Ed
Old Dec 19, 2004 | 02:01 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum. Ed the members in this forum are very knowledgeable about these trucks, they will be by..... and help you with your question.
Good luck with your problems.
Enjoy FTE
Are you trying to hammer them out.. or using a press to push them out?
Have you removed the snaip rings?
Old Dec 19, 2004 | 02:07 PM
ranger894x4
Thanks for the welcome. I'm looking for the proceedure on removing the front axle shafts to replace the bearings and U-joints on the shafts themselves. Thanks Ed
Old Dec 19, 2004 | 11:56 PM
hreed's Avatar
hreed
There are 3 joints on the front axles. The two outer ones are pretty easy to get out. You need to remove the wheels and brake rotor to pull the axles. The right one has a slip joint with a rubber boot that will allow removal. The left one should just pull out. The center one is a lot more difficult. You either need to replace it while the axle shaft is still installed in the differential (which can be quite tedious) or drop the complete front end to access the C-clip holding the shaft in place. If you do drop the front end, there is a neat and simple modification you can make so that if you need to ever replace the center joint, the shaft will come out. Let me know if you need the info for that.
