vapor lock?
Old Aug 2, 2000 | 09:38 AM
88rangerman's Avatar
88rangerman
vapor lock?
My 88 4cyl fuel injected Ranger has been losing power and dying lately (it has been very hot in our area). This typically occurs after making three or four short trips (5 - 10 miles) with a five or ten minute stop in between each trip. Then as I am travelling, the engine starts to lose power and cuts out completely. After cooling off for about 30 minutes the truck will then go again. I recently had the fuel pump (on the frame under the driver) replaced by a mechanic hoping that would solve the problem - without any luck. I have had the truck for about 5 years and haven't had this problem until now. Any ideas about what could be causing the problem would be greatly appreciated.
Old Aug 3, 2000 | 11:46 AM
jb85302's Avatar
jb85302
vapor lock?
Check to see if any fuel lines are collapsing or maybe if you had exhaust work done on it lately it could be running too close to the fuel line. My truck would only run when it was cool and it ended up being the module in the dist. My truck usually just died though(no loss of power). Hope this helps.
Jeff
Old Sep 9, 2000 | 02:58 AM
shadetree351's Avatar
shadetree351
vapor lock?
I agree with Jeff. It sounds like a classic example of the module in the dist. needing to be replaced. By the time you can get it in for service, it has cooled down and will run fine. Yours is one of the Fords which is supposed to be recalled to have that replaced. But I wouldn't wait for the recall, get the thing replaced, and see if there's somewhere else it can be mounted, away from all the heat of the engine. That's what's causing it to malfunction.
Shadetree 351
Old Sep 9, 2000 | 03:17 AM
shadetree351
vapor lock?
dougd347
15
Oct 29, 2022 04:53 PM
filadog23c
Nov 6, 2019 10:45 AM
FordGirl2009
2009 - 2014 F150
Jul 28, 2015 04:07 PM
Hogtrapper
18
Dec 15, 2014 09:53 AM
Mike450
15
Jun 27, 2013 04:32 PM
