Modular V10 (6.8l)
Ned help with engine code P 1131
Old Dec 19, 2004 | 01:39 PM
jabo99's Avatar
jabo99
I have a 1999 V10, (Dutchstar Motorhome) I am getting a Code P1131 which my reader says is a Manufacture Control, Fuel/Air Metering. Any body have a sugestion as to where I should start looking? Thank you, I would appreciate any help.
Old Dec 21, 2004 | 11:17 AM
kenneBF250V10's Avatar
kenneBF250V10
Sounds like maybe an O2 sensor.
Old Dec 21, 2004 | 05:56 PM
jabo99's Avatar
jabo99
Thanks for the tip, i will check them out. I have been told that the 1131 code refers to the right bank, so maybe i could swap the left and righy o2's and see if any thing changes?
Old Dec 22, 2004 | 10:42 AM
kenneBF250V10
Let us know what happens.
Old Dec 23, 2004 | 06:26 AM
jabo99's Avatar
jabo99
Will do. With the Holidays and all it may be a week or so.
Old Dec 29, 2004 | 11:41 AM
raybarbee's Avatar
raybarbee
Thumbs up Code 1131
I had a problem with my 2003 Gulfstream E350/V10 motor home where the engine would not run at high rpm. The longer I drove it, the lower the usable rpm became until I reached the point where I could only drive 45 mph to limp home. Each time the problem occurred I would see error code 1131 or 1132, or both. The problem ended up being a huge amount of rust in the fuel tank. A new fuel pump/filter and thorough flushing of the tank was the solution. I hope your problem is not rust because removing the tank on a RV is nearly impossible without putting the RV on a lift. In my case I lowered the tank to the ground and crawled under the RV to work on it. Good luck.
casanova76
1997 - 2003 F150
Mar 14, 2015 05:22 PM
calialx1
Apr 24, 2011 11:12 PM
sunsettt
Oct 17, 2007 02:15 PM
zenpal
16
Nov 6, 2006 09:10 AM
