heat troubles
Old Dec 19, 2004 | 11:33 AM
jjdurlin's Avatar
jjdurlin
heat troubles
1994 f-150 6cy 4.9, 4x4 with A/C, My heater will not blow hot air, not even warm air. Changed thermostat, flushed heater core. both hoses going to heater core are hot to the touch, truck runs at normal temperature, never overheats. Heater core looks brand new from the outside. Pleeease help, live in northwestern PA, its 20 degrees here.
Old Dec 19, 2004 | 11:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum. The members in this forum are very knowledgeable about these trucks, they will be by..... and help you with your question.
Good luck with your problems.
Enjoy FTE
Old Dec 19, 2004 | 02:44 PM
92supercab's Avatar
92supercab
If you think your heater core is fine, try looking at the heater controls. Maybe the blending door is stuck open or the swithches aren't working.
Old Dec 19, 2004 | 06:42 PM
jjdurlin's Avatar
jjdurlin
blend door functions correctly, hot to cold switch on dashboard works i think, when you switch it to a/c it works.
Old Dec 19, 2004 | 06:43 PM
jjdurlin's Avatar
jjdurlin
i've heard rumors of some kind of heater switch in the engine compartment failing on ford trucks???
