Sponsored by: Auxito
interior lights
Old Dec 18, 2004 | 08:48 PM
chaser1602's Avatar
chaser1602
Smile interior lights
does anyone with an 01 lariat have an interior light in there cab that stays on until you put the key in and start the truck?If so were is that sensor located at.I need to replace mine
Old Dec 18, 2004 | 08:51 PM
triton_2002's Avatar
triton_2002
Spray some WD40 in the door latch mechanism, the switch is in there and this is fairly common. If that doesn't do it, then it may be a wiring problem or the switch may be bad.
Old Dec 26, 2004 | 12:27 PM
chaser1602's Avatar
chaser1602
Cool
thanks for the info.finally got warm enuf to look at.wd40 didnt work.
