1978 - 1996 Big Bronco
3 inch Rancho lift problems
Old Dec 18, 2004 | 11:36 AM
rafe1269's Avatar
rafe1269
Cool 3 inch Rancho lift problems
I just put in a 3 in. lift on my 82 bronco, tires bow in. they said all i needed after the installion was to get it aligned and install 1.5-2.0 degree chamber adjustment sleeves. Shop is telling me that i need drop brackets for the i-beam and radius arm. Who's correct?
Old Dec 18, 2004 | 11:56 AM
bossind's Avatar
bossind
Both are. Where did you get your kit? Should of came with the TTB drop brakets.
Old Dec 18, 2004 | 01:03 PM
greystreak92's Avatar
greystreak92
Ditto to Bossind, anything over 2" of suspension lift will need drop brackets for the axle pivot mounts and 1) drop brackets for the radius arms or 2) longer-than-stock raduis arms. Otherwise getting caster and camber into line will be impossible.
Old Dec 20, 2004 | 04:44 PM
rlh's Avatar
rlh
With that particular lift, the axle pivot drop brackets are essential. You may or may not need the adjustable caster/camber bushings . . . it just depends on the individual truck. You probably need radius arm drop brackets or extend radius arms also.
Shadowrider123
Apr 25, 2015 10:19 PM
T_Cooksey88
Jan 6, 2015 06:32 AM
Vince79vette
Nov 20, 2014 01:30 PM
R3surr3cti0n
Large Truck
Apr 6, 2014 06:11 PM
old blue beast
Jan 18, 2013 06:59 PM
