New 295 KO'S
Old Dec 18, 2004 | 03:42 AM
Unclemuck's Avatar
Unclemuck
New 295 KO'S
Just put on a new set of BFG All Terrains in 295-75-16 on stock rims. I love it! Yes 295's will fit. (but boy is it close)lol ......I'm puttin the DR mini packs on order! I think other 285's would all be OK, its just the super square shoulder that gets it so close to the inner wheel well. Anyway, HAPPY HOLIDAYS TO ALL (and thanks Santa for my new skins!!) LOL
Old Dec 18, 2004 | 10:40 AM
psajunk's Avatar
psajunk
We need pictures!!!
Thanks
Old Dec 18, 2004 | 02:02 PM
Unclemuck's Avatar
Unclemuck
I posted a few new pix, check my gallery.
Old Dec 18, 2004 | 03:11 PM
makomarine's Avatar
makomarine
Which gallery? ... don't see your name in gallery how do we search for it... 4x4, year,
Old Dec 18, 2004 | 03:44 PM
Unclemuck's Avatar
Unclemuck
Click on unclemuck and go to gallery.
Old Dec 18, 2004 | 03:50 PM
Oval_obsessed's Avatar
Oval_obsessed
I like the looks when you fill the wheelwell with the tire. The BFG's are always good looking tires.
Old Dec 18, 2004 | 05:13 PM
Unclemuck's Avatar
Unclemuck
I know, I was looking at it today, and I can't decide if I even want to level the front end.
Old Dec 18, 2004 | 07:04 PM
xr7390GT's Avatar
xr7390GT
Smile
Unclemuck,
Put some V 0r U codes up front. I put U codes on V10 Ex, gained 1.5 in height. Level front to back and better ride. I put 60K on 265 BFG's before I replaced with 265 Revos.
Old Dec 19, 2004 | 05:40 AM
Unclemuck's Avatar
Unclemuck
That sounds like a good way to go. I think the front end could use a little stiffer spring. 65K would work for me, I only pu about 7K a year on this thing. By that time I'll be ready for a Lincoln.....lol
Old Dec 19, 2004 | 09:04 AM
Fordone's Avatar
Fordone
Originally Posted by xr7390GT
Unclemuck,
Please excuse my ignorance of the "V and U code" info. Please explain the difference between the two. I am fam. w/tire speed rating but not springs; if in fact that is what "V or U" refers to. I intend to buy a new Excursion after the Xmas Holdiays and will have Ranch Hand type bumpers installed front and rear. These will add weight at both ends and the idea of HD springs that raise the height 1.5 sounds great.
Many thanks and Merry Xmas,
Fordone
Old Dec 19, 2004 | 10:44 AM
Unclemuck's Avatar
Unclemuck
Fordone,
The code for the springs is stricktly a Ford code. The higer the letter the higher the spring rate. Depending on the application (f350, F250...etc.) was how the letters were assigned.
Front axle weights used are 4080, & D code springs for the PSD and 3680, & C code springs for the V-10
Application---Code---Capacity-----Rate----Travel --------- V-10 ----- PSD
------------------------------------/spring---to Max Cap ----height ----height
---------------------------------------------------------------- change --- change
Exc V8 -------- B ----- 4100 ----- 330 ----- 5.02 ---------- -0.25 ----- -0.66
Exc V10 ------ C ----- 4300 ----- 350 ----- 5.01 ----------- 0.00 ----- -0.37
Exc PSD ------ D ----- 4700 ----- 380 ----- 5.14 ---------- +0.33 ------ 0.00
F250/350 All springs are computer selected
Also the use of a rear sway bar and what size it is package dependant
Application---Code---Capacity-----Rate----Travel ------------- V-10 ----- PSD
--------------------------------------- /spring---to Max Cap ----height ----height
------------------------------------------------------------------ change --- change
SD-250/350
------------------ S --------4000 ----- 370 ------ 4.34 --------- +1.22 --- +0.88
------------------ T --------4400 ----- 390 ------ 4.63 --------- +1.42 --- +1.11
------------------ U --------4800 ----- 410 ------ 4.89 --------- +1.60 --- +1.32
------------------ V --------5200 ----- 430 ------ 5.13 --------- +1.77 --- +1.50
F450 ----------- W --------5600 ----- 450 ------ 5.34 --------- +2.77 --- +2.52
F550 & 350/ DRW with Snow Plow prep Package
----------------- X-------- 6000 ----- 470 ------ 5.54 ---------- +2.90 --- +2.68
Old Dec 19, 2004 | 10:48 AM
Unclemuck's Avatar
Unclemuck
The table is a little jumbled, but the + numbers mean how much higher an Excursion will sit in the front with that letter spring.
Old Dec 19, 2004 | 07:27 PM
xr7390GT's Avatar
xr7390GT
Talking
Thanks Unclemuck. That charts been floating around awhile, from Bruce at ford-trucks. For V10 stick with U codes. With the V or X you will have to raise the rear.
I had Edelbrock shocks but they blew out with around 70K miles on them. Just replaced with Monroe Reflex and I also used longer front shocks (F-350 application) to compliment the U codes. Ride is even better now.
Old Dec 20, 2004 | 11:22 PM
woody_f250's Avatar
woody_f250
What would it cost for the V or U code springs? For the diesel is teh V code too much if the back is stock height?
Old Dec 21, 2004 | 12:04 AM
quietman's Avatar
quietman
<IMG SRC="http://www.martialartsacademy.org/offroadpicsmall.jpg">
Man this stuff is both fascinating...and frustrating for me. I bought a 2005 PSD 4x4 Eddie bauer Excursion the last day of sept, and so far have 7,000 miles on it, many, many of them hard off-road ones.
I am in great need of more front end travel, more shock damping, and larger tires, but also like the nice ride etc.
Until now I had no idea about the different springs and was trying to decide between:
After market springs
Longer hangers
spring packs
I would like to put larger tires and have more spring travel with minimal lift, say two-three inches max, if possible.
I would love any and all opinions and information, I really need to do something soon, many more trips planned right away...
Thanks!
Quietman
www.roenation.com
