Light Prob
Old Dec 17, 2004 | 10:48 PM
donna_n_mike's Avatar
donna_n_mike
Thumbs down Light Prob
I have a 98 3.0 V6 Ranger and at night when you have your headlights on bright for the first time since start-up and turn them down to dim, the lights completely cut out except for the parking lights until you put them back on brights real fast and turn them back to dims...any other time and they work fine. This has only happened twice, very strange. Was wondering what the problem may be!
-Mike
Old Dec 18, 2004 | 07:28 PM
Ken00's Avatar
Ken00
The first thing that comes to my mind is a defective multifunction switch.
Old Dec 18, 2004 | 11:11 PM
donna_n_mike
How hard is it to fix and how much to replace it?
Old Dec 19, 2004 | 07:34 PM
Ken00's Avatar
Ken00
I got your PM and replied, for my 2000....
«2000 Ranger Table of Contents»
«Group 2: Chassis»
«Section 211-05: STEERING COLUMN SWITCHES»
«REMOVAL AND INSTALLATION»
Multifunction Switch
Removal
µ 1. Disconnect the battery ground cable.
µ 2. Remove the ignition switch lock cylinder.
1 Insert the ignition key into the ignition switch lock cylinder and turn to the RUN position.
2 Push the ignition switch lock cylinder release tab with a punch while pulling out the ignition switch lock cylinder.
µ 3. If equipped, remove the tilt wheel handle.
µ 4. Remove the upper and lower steering column shrouds.
1 Remove the screws.
2 Remove the upper and lower steering column shrouds.
µ 5. Remove the multi-function switch.
2 Disconnect the electrical connectors.
3 Remove the multi-function switch.
Installation
µ 1. Note:
When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn its strategy.
To install, reverse the removal procedure.
