custom stainless bumpers
Old Dec 17, 2004 | 10:18 PM
fords_forlife's Avatar
fords_forlife
I have a 1980 f-250 that will eventually become a stepside and want to custom make some stainless steel bumpers. The problem is that most articles I find are on customising stock bumpers or making them out of reg. steel. I need help on where to begin. Can I weld stainless with either a mig or stick welder or does it require a tig welder. If I weld it can i polish the blueing around the weld away or will the weld show no matter what. What would be the best type of stainless to get with out having to high a steel content so that I don't have to keep polishing rust away everytime the bumper gets wet. Any other opinions would be great.
Old Dec 18, 2004 | 03:31 PM
FLgargoyle's Avatar
FLgargoyle
You can weld stainless with a mig; make sure you have the right wire. You may need a different gas mixture for best results; ask a welding supplier. I like 304 stainless; it is easily bendable, available in many shapes, and it welds like a dream. It's what they use for sailboat fittings. You want a stainless with a high chromium content; that's what makes it stainless. Just polish out any heat discoloration. 304 is difficult to machine, tho'. Use low RPM, high pressure, and some oil if you need to cut it or drill it.
78bigbronco
Garage & Workshop
20
May 31, 2010 06:38 AM
barnbridge
Mar 5, 2009 09:19 PM
pimt1ton
All Things Towing
Sep 30, 2006 11:14 PM
f150_514ci
Garage & Workshop
15
Nov 17, 2005 03:33 PM
ocdmachine
Appearance & Dress-Up
May 2, 2004 12:51 PM
