400 build up
Old Aug 11, 2011 | 09:08 PM
smokeyb97's Avatar
smokeyb97
Originally Posted by packlet
take a look at the comp cams 255deh.
I agree with Packlet. The Comp 255deh is what I use and it produces great torque, especially at the low end.
Old Aug 14, 2011 | 11:53 AM
mustange70's Avatar
mustange70
Go with a 750 cfm carb, headers, the 255 deh cam, straight up timing set and a set of zero deck pistons for a good low rpm high tq motor. 600 cfm carbs are tooo small for these motors, the. heads have relatively large ports and the long stroke benefit from the larger carbs.
Old Aug 14, 2011 | 08:56 PM
wyoming4x4's Avatar
wyoming4x4
yeah!
Doing a similar engine for a friend but running a little more duration in the 265 because of the 4speed tranny. Good low end and the dual friction clutch, centerforce. 750 annular quick fuel carb. really like these carbs for 4wd and 1:1 linkage for the low end torque. MSD igniton.
Old Aug 28, 2011 | 05:54 PM
lasg4's Avatar
lasg4
What kind of vacuum is the engine pulling. Tring to find as much info on cams and vaccum for mud draging. You have to pull 19inches in one class and 17inches in another.
Old Aug 28, 2011 | 06:38 PM
wyoming4x4's Avatar
wyoming4x4
268 comp?
my 268hi energy. was about 17". what is you elevation? elevation will change your vacume signal also. run a cam little bigger in another truck and gettin about 15" vacume at 5000' elevation. will research this a little for you. kinda forgot some of this info from back in the day.
Old Aug 28, 2011 | 08:53 PM
smokeyb97's Avatar
smokeyb97
Mine is pulling 17-18 @ 700+/- el. above sea level.
4bars13stars
34
Aug 28, 2016 07:56 PM
Sgt.allen414
18
Jun 23, 2015 12:18 PM
NW 150
Feb 16, 2015 09:05 AM
Stratosss
Jan 14, 2015 08:30 AM
79 explorer
38
Feb 3, 2014 01:50 PM
