testing a condensor
Old Dec 17, 2004 | 01:23 PM
ford390gashog's Avatar
ford390gashog
testing a condensor
does anyone know what the resistance value should be when testing a distributer condensor
Old Dec 17, 2004 | 04:19 PM
Franklin2's Avatar
Franklin2
It should read open. The needle should jump a little bit, and then settle down to infinity. If you get a reading, it's shorted. You should be able to short the condensor out, and then the needle on the meter will jump again(the meter is charging the condensor whe the meter jumps).
Old Dec 17, 2004 | 05:06 PM
ford390gashog
so it should read 0.00
Old Dec 17, 2004 | 06:25 PM
Bob Ayers's Avatar
Bob Ayers
No, after the initial charge, it should read like an open circuit.
Old Dec 17, 2004 | 07:51 PM
ford390gashog
i am bad when it comes to electricla what does it read when it is a open circuit and where would i put the probes on it being it only has one wire
Old Dec 17, 2004 | 07:55 PM
Bob Ayers's Avatar
Bob Ayers
If you turn your ohm meter on, and with the leads not touching anything, this should be the reading you have across a condenser. The case of the condenser is one of the terminals.
mlc8761
Sep 13, 2013 07:16 PM
LongRider
Jul 24, 2013 08:04 AM
B Dobz
Aug 10, 2007 03:33 AM
GeneStoner
Mar 24, 2005 11:41 AM
Nitro
Mar 27, 2000 11:35 PM
