Anybody burning corn???
Old Dec 29, 2004 | 11:17 PM
  #31
Maxium4x4's Avatar
Maxium4x4
Findlay, about an hour and a half north of Columbus....Power Show is coming in Jan at the fair grounds........good chance to check out the corn furnaces
Old Jan 1, 2005 | 03:04 PM
  #32
Stampede's Avatar
Stampede
How much corn do you use a year? And do you only heat with corn?
Thanks.
Old Jan 1, 2005 | 03:18 PM
  #33
Maxium4x4's Avatar
Maxium4x4
Stampede
I went a little wild last year. This year I have around 150 bu I plan on using.
My system is a heat pump forced air and corn burner. I have a sail switch so when one runs the other closes off. Both systems share a common duct for return and heated air.
When the temps are mild like today..50 degrees ..not much heat is required so I shut off the corn burner.
ford2go
Apr 11, 2019 05:08 AM
ford2go
Jan 24, 2018 07:01 PM
tseekins
Feb 2, 2012 07:55 PM
DMAX-HD
Feb 4, 2005 01:08 PM
websthes
Dec 14, 2004 05:07 PM
