Ranger Performance
Old Nov 3, 2000 | 08:32 PM
frankensteins4x4's Avatar
frankensteins4x4
Ranger Performance
[font size="1" color="#FF0000"]LAST EDITED ON 03-Nov-00 AT 09:41 PM (EST)[/font][p]I have a '87 2.9L,4x4 Ranger w/31 10.5's on her and she needs a locker in the rear end. I would like to know if they make a "Easy Locker" or a "Lock Rite" for the 7.5 rear end,where to get one and how much. Also if anyone has one of these are they worth the money. I know how well the Detroit Lockers work because I have one in my full size but I am new to all this little stuff. Also has anyone had any problems with the hydraulic lifters collapsing in these engines. Mine taps a little when you first fire her up. Thanks for any advice.
'78 F150 390FE 44" Gumbos
'87 Ranger 2.6L 4x4
Old Jan 4, 2001 | 05:41 PM
omarkayak's Avatar
omarkayak
Ranger Performance
I recently rebuilt my front and rear gears...I put in 4:56 gear set and also a limited slip diff. I don't know if your planning on changing gears but heres the info on mine in case you do.I got them from Fourwheel Parts Wholesalers. They guarentee the lowest price out there.
( www.4wheelparts.com ) The cost on the rear gears is $139.95, the front ones would be $184.95, the rear limited slip from Auburn would be $379.95. the master install kits needed for all this would be $85.00 for the rear and $79.95 and if you don’t have a 3.73 gear ratio or higher you will need to replace the carrier and the cost on that would be $89.95. The labor for the fornt was about $350.00 and the labor for the rear was about $250.00
Hope that helps....Steve
natewoz
Offroad & 4x4
Dec 30, 2015 08:05 AM
dmtulsa
Feb 7, 2011 08:14 PM
FBFord
Offroad & 4x4
33
Oct 29, 2006 11:53 AM
jokerforever
Jun 15, 2005 08:54 AM
lordthirteen
Offroad & 4x4
13
Feb 19, 2003 09:54 PM
