Ford 9"
Old Dec 15, 2004 | 06:44 PM
Deashider's Avatar
Deashider
Ford 9"
Does anyone know where I can find info on my Ford 9" rear end? The tag says:
WDM-BC2 6FD
3.00 9 386D
Old Dec 15, 2004 | 07:09 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Tag says it has a 3.00 ratio and open (non limited slip) differential. Someone here can probably tell you the year of manufacture from the other info you posted.
Check out www.currieenterprises.com to learn more about the 9" and see all sorts of cool hot rod goodies for it.
Old Dec 16, 2004 | 12:43 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Dec 16, 2004 | 09:19 PM
Jerry Gougeon's Avatar
Jerry Gougeon
Ford 9" :
Deashider : If you do a Google search with ford nine inch and put the spaces between the words you will get almost 400,000 hits in less than 4 sec .
If there is anything about a Ford 9" , stock or aftermarket you can't find here it is not relative .
There are over 20,000 companies in North America that also remanufacture these diffs for every application from street rods to Indy Cars .
Old Dec 17, 2004 | 05:15 PM
286merc's Avatar
286merc
That code was used in:
78 Bronco
75-79 F100
75-79 F150
Non locking but with the large axle bearings and the HD 31 spline axles. Good find.
