Speedometer Problem
Old Dec 15, 2004 | 02:12 PM
RangerJ91's Avatar
RangerJ91
Speedometer Problem
I have a '91 Ranger with a 3.0L engine and an automatic OD tranny. My speedometer reading is about 5 - 7 miles above normal on a warm day.
The needle is not erratic or jumpy. However, when it gets cold, say below 40 degrees, the speedometer reads about 20- 25 mph above normal. I am thinking this is not a mechanical problem. I looked at what should be the speedo cable coming out of the transmission but there is an electric sensor above it. I assumed the speedo was driven by the cable. What does the sensor do? Could that be the problem?
Old Dec 15, 2004 | 03:08 PM
el conquistador's Avatar
el conquistador
the reason for the 20-25 MPH on the speedo when it is cold out is due to insufficient lubrication of the speedometer head. ford put a bulletin out for the problem. the only fix for this is to replace it.
as for the 5-7 mph on a normal day, did you put different size tires on your truck?
Old Dec 15, 2004 | 03:32 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Welcome to FTE!!!
In lieu of replacing the head, some people have reported that a speedo shop can repair the problem.
Old Dec 15, 2004 | 03:41 PM
RangerJ91's Avatar
RangerJ91
Thanks for the info.!...I have had 14" rims with the same size tires on the truck since I have had it, about 10 years. I sort of figured out there may have been a problem with the speedometer reading about a year ago when it occured to me that everybody was passing me up all the time. I didn't worry about the difference since it was consistent I could just drive 5 mph faster than the speed indicated... but when it jumps to 20 I am just bait for the police....I am not sure what tires are supposed to come with the Ranger..I asked around but never could get a straight answer...I had a friend that had a Ranger that had 16" tires...so I am not sure.
Old Dec 15, 2004 | 04:06 PM
CowboyBilly9Mile
On the drivers side, in the door jam area, look around for a sticker with various info, including recommended tire (and rim) size.
