89 Ranger Fan switch/resistor troubleshoot
In my 89 Ranger the heater fan only works on the highest setting. I thought first it was the motor because when my buddy borrowed the fan for his Ranger it only worked on hi too. But this weekend I tried it with 3 different fans, and they all worked only on hi as well, which leads me to believe it's either the switch or the resistor. In your experiences, which has been more prone to keep the fan from working in all settings, switch or resistor? Where is the resistor located so I can troubleshoot it? I suppose I have to get out the multimeter and do a bunch of testing to see when/where I'm getting/not getting power.
Problem solved.....mostly.....
My old 87 F150 had the same resistor as the Ranger. Went to remove the resistor from the Ranger, the plug was so badly corroded I couldn't get it out. So out come the side cutters, removed the plug & resistor from the Ranger, and the plug from the F150, and spliced in the F150 plug into the Ranger wiring harness (after verifying wire colours and pin positions, of course). Now I have speeds 1, 2, & 4. For some reason speed #3 still isn't working, could be a bad connection (the green wire) that I will revisit after the cold snap is over. But at least I have a couple lower speeds now, instead of turning it off & on. Thanks for the help
Supercab
1983 - 2012 Ranger & B-Series
20
10-16-2013 03:08 PM
clint39
09-12-2012 09:36 AM
tractoman
03-30-2006 10:51 PM
