Sponsored by: Auxito
Manual Hubs
Old Dec 15, 2004 | 12:36 AM
2001gocougs's Avatar
2001gocougs
Manual Hubs
Is there anyway to convert the front end to manual hubs like the older front axles? When in 2wd does the front differential turn? My 1998 has the floor mounted selector.
Old Dec 15, 2004 | 07:03 AM
kingfish51's Avatar
kingfish51
Your truck does not have front hubs. It has CV joints at the wheel. The front axle always turns by the motion of the wheel. Power is engaged at the front diff.
Old Dec 16, 2004 | 10:37 PM
kspilkinton's Avatar
kspilkinton
Check out this link:
http://www.fordtrucks.com/forums/sho...d.php?t=309867
you may find the second post from the bottom to be the most helpful.
You could spend several thousand dollars if you really want to have the ability to get out and lock 'em in. Fabtech makes a straight axle swap kit. It costs some bucks and uses a dana 44 or 60 monobeam axle. I see a problem with the difference in lug patterns between the two... metric versus SAE. Then you'd have to swap the rear axle too, and then that opens up a whole can of worms by itself.
-Kerry
