Bad U-Joint?
Old Dec 14, 2004 | 08:52 PM
79 posi's Avatar
79 posi
Bad U-Joint?
I've got a 92 f-150 2wd that is starting to get an intermittant vibration. not much in 1st and 2nd, although, more when accelerating. progressively getting louder.
The u-joint right behind the carrier bearing (or whatever the rubber surrounded joint is called) looks bad. I can wiggle it pretty good and can see that the rubber around a couple of the end caps is shot.
Is this causing my vibration?
Thanks
Old Dec 14, 2004 | 08:56 PM
andym's Avatar
andym
I would say almost definately. They're super easy to change yourself.
