fuse blowing
Old Dec 14, 2004 | 12:28 AM
badass truck's Avatar
badass truck
fuse blowing
i have a 94 f150 2 wheel drive. i keep blowing a fuse in my truck and i have no clue to what is doing it. its the fuse that runs all my gauges, except the speedometer. when the fuse blows it makes a really loud chime like 12 times, louder and a heck of alot more annoying than the door chime. it happens i noticed only when i shift. not all the time but if i'm goofing around and shifting gears or downshift. or even when i put it in reverse to fast sometimes it does it. i have reason to believe my clock spring is out also because i have no cruise,horn, and my air bag light flashes. would this be part of the problem. any suggestions and if it is the problem are they hard to replace?
Old Dec 14, 2004 | 08:27 AM
sandrat's Avatar
sandrat
Do you have an automatic or a manual transmission? I'd say something is shorted to power maybe inside the column. Check what components are on that fuse, and find a wiring diagram to follow the harness, see where all the failing components meet.
Old Dec 14, 2004 | 09:01 PM
badass truck
its a automatic
