Sponsored by: Real Truck
gear ratio
Old Dec 14, 2004 | 06:52 PM
ZRX's Avatar
ZRX
gear ratio
Im goig to order my f350 (2005) v-10 super cab. I plan on putting on 35'' tires, what rear end gears do i want to order 3.73, 4.10 4.30 ? I will use the truck to plow snow and pull a 8000# trailer once a month or so. THANKS!!!
Old Dec 14, 2004 | 06:55 PM
tomwhysy's Avatar
tomwhysy
how much driving do you do?
410 are for better take off and 373 better highway with 35" leawe 430 alone untill you wanna go rock crawling
Old Dec 14, 2004 | 08:54 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I'd order the 4.30's since the option doesn't cost much compared to what it costs to change them later. 4.56 or 4.88 would be a better gear with 35" tires in a truck used for towing, but the 4.30's will do ok for most situations, just be slower up the hills with the trailer in tow. The V10 likes to rev, so the lower the gear, the better for pulling (up to a point, of course).
Old Dec 15, 2004 | 04:43 AM
ZRX's Avatar
ZRX
will my gas milage suck for everyday driving with the 4.30's ? What kind of rpms wiil the 4.30's have a 75 mph? Will the truck still be able to pull decent with 4.10's W/ 35's? I dont pull every day , but Im looking for a good compermise between the two! It will be a every day driver more than just a plow/ tow truck. Anybody have any experience with the new 05's V-10?
Old Dec 15, 2004 | 04:59 AM
Edmo's Avatar
Edmo
I have the 4.30s and they turn my 33" tires and pull my 8,000 lb travel trailer very well...
Remember, as your tires get bigger, you effectively change your gears to a lower number. As compared to the factory tires, the 35" tires will take your 4.30 gears and "effectively" make them around 3.90.
Here is a link to play with for tire size & gear ratio...
Wheel & Tire Calculator
Sorry that it is a Dodge based link... My Dodge loving bud sent it to me. Their trucks might not be as good, but their tire calculator works well.
Edmo
Old Dec 15, 2004 | 09:31 AM
cburgess's Avatar
cburgess
AHHHHHHHGGGG! I can't believe webmaster allowed you to post a link to a Dodge site.
Here is a link to a 'neutral' site. Plus they have other cool calculations.
http://www.bncoffroad.com/tire_gear_cal.html
Old Dec 15, 2004 | 09:41 AM
a12play12's Avatar
a12play12
Hey ZRX,
Here is a link to a FORD calculator http://www.andthensometoo.com/calc/tiregear.php,
im running 4.10 on 35's with a 460 in my supercrew and have no trouble pulling a trailer, or with highway travel. You will have more than enough motor to do what you are looking for. SoCal is correct though, you may want to go with the 4.30 now cuz changing them later is $$$$$$.
Good Luck, R.
Old Dec 15, 2004 | 09:51 AM
aircheck's Avatar
aircheck
I don't believe the 3.73 rearend is available with the V-10 anymore. I believe they discontinued that axle with the '05 model year, so you're limited to the 4.10 or 4.30 as stock options with the gas engine. I didn't see the 3.73 on the option sheet when I ordered my '05 250 in October. I've got the 4.10 and am quite happy with it so far. The acid test will be getting my trailer hooked up and on the road this weekend.
Old Dec 15, 2004 | 10:08 AM
Big Orn's Avatar
Big Orn
You'll be satisfied with the 4.30's
That's my vote.
Maybe you should have setup a poll.... ???
Old Dec 15, 2004 | 10:11 AM
Daryl Hunter's Avatar
Daryl Hunter
No need to go to some other site.
It's pretty straightforward to calculate the difference in required ratios.
Divide the new tire size by the old tire size as in 35/31.65 = 1.106, now multiply the stock rear end ratio (which I believe is 4.10 for the new V10) by 1.106 as in 4.10 x 1.106 = 4.534.
So you really need something higher than the 4.30, but that would be better than going with the 4.10 for sure. If you aren't going to be towing the 4.30 would probably be just fine, but since you are going to be towing some heavier loads then you might consider going with aftermarket gears up in the higher numbers.
Old Dec 15, 2004 | 11:26 AM
igotoneforya's Avatar
igotoneforya
I have a 03 V10 EX and 3.73 gears and 35 inch tires. I do not pull much and am not disappointed with the performance. I get better than 11 in town and 14 or more on the road at 75-85 mph. I do not pull a trailer often and it is not heavy when I do, but a monthly pull of short distance and 8000 lbs will still warrant 4.30 or at least 4.10s in my opinion. Had I been smarter and went with the 4.30 in the first place, I would have went to 37 inch tires. If you do alot of traveling without a trailer, I recommend the 4.10s over the 4.3. I have plenty of power unloaded in town and on the road and your new V10 has more power than mine. My last truck was a 5.8L Bronco with 35s and the 3.43 gears. It was not worth the cost to change the gears in that one and the X is much better than the Bronco. I am not even considering the gear change now. A supercharger will come before gears are thought about. I know there is at least one more V10 with 35s and 3.73 gears and he is happy with it as well. Whatever your decision is, I am sure you will be happy.
Old Dec 16, 2004 | 02:19 AM
Zenunekim's Avatar
Zenunekim
Go with the 4.30's. It's only an extra $350 or so. Much cheaper now than to have to change them later. I have 4.30's with 35's and it is barely enough (in my opinion). When driving in the city it sometimes shifts into overdrive at too low of a speed and bog down the engine. On the freeway/highway it runs perfectly. I think that 4.56's would be perfect for 35's, but it is not worth the $ for me to go from 4.30's to 4.56's.
Old Dec 16, 2004 | 08:33 PM
ZRX's Avatar
ZRX
what year is your truck?
Old Dec 17, 2004 | 09:20 AM
Zenunekim's Avatar
Zenunekim
I have a 2003 F-250 Crew Cab V-10.
Old Dec 17, 2004 | 10:28 AM
ZRX's Avatar
ZRX
anyone have any reviews of the NEW 2005 V-10? (power, compaired to the o4's , gas mileage , etc.?)
