Holley identification
Old Dec 14, 2004 | 06:24 PM
dino360's Avatar
dino360
Cool Holley identification
I need to rebuild my Holley and I don't know which one I have so I can order the right kit. I know it is a 4 barrell and that it is either 600 or 650cfm. I bought it new in 95 from Summitt as a kit with the cam and intake.I can't find any data plate on it or anything, maybe I wansn't looking in the right place. It has backfired several times through the carb, so I am sure the power valve is also gone. How much can I expect to pay more or less for the kit and power valve ? Thanks.
Old Dec 14, 2004 | 10:27 PM
sdkoz's Avatar
sdkoz
On most Holleys the list number can be found on the right side of the choke air horn. On my 600 cfm 4160 the no. (1850-6) is on the main body assy facing forward just below the choke plate. The following link is to a Holley carb rebuild manual that shows the list no. location: http://www.holley.com/HiOctn/TechSer.../Instruct.html
This one is a carb list showing tech info such as cfm, jet size, etc. for each model: http://www.holley.com/HiOctn/ProdLine/CarbList.pdf
I got mine at NAPA; not sure of the exact amount, but probably ~$25. I saw them at Summitt for $21.95. The power valve is in the kit.
Old Dec 16, 2004 | 02:33 PM
sdkoz's Avatar
sdkoz
correction
Originally Posted by sdkoz
...I got mine at NAPA; not sure of the exact amount, but probably ~$25.
Correction: it was $34.95 at NAPA.
Old Dec 16, 2004 | 05:18 PM
dino360's Avatar
dino360
Cool
Mine says 1850-1
0265.
I found a rebuild kit for holleys and the part number is 37-720, is this the right one for my carb?
Old Dec 16, 2004 | 05:21 PM
dino360's Avatar
dino360
Cool
Never mind about the part number, I found it. What is the difference between a renew kit and a trick kit?
Old Dec 16, 2004 | 11:13 PM
LxMan1's Avatar
LxMan1
A trick kit has some extra tuning parts like lighter secondary springs to make the secondaries open sooner, different accelerator pump cams for more adjustments and things like that. It still has all of the parts ro rebuild it too.
You have an older, all metal (no plastic choke rods or secondary spring cover) 600CFM carb. It is a good carb. That number sounds right for the kit. AutoZone has a good deal on kits too.
Old Dec 17, 2004 | 05:18 PM
dino360's Avatar
dino360
Cool
Thanks for the help guys.
jhweigel
25
Mar 3, 2016 05:15 PM
mos68x
13
Dec 2, 2015 07:39 AM
AbandonedBronco
189
Jan 22, 2015 11:49 AM
HarlanThomas
15
Apr 9, 2010 02:10 PM
DailyDriver
Jul 21, 2002 12:14 PM
