Sponsored by: Auxito
Engine shakes on startup
Old Dec 14, 2004 | 03:36 PM
Goudey's Avatar
Goudey
Wink Engine shakes on startup
My 97 f-150 4.6L shakes after staring up for a minute or two....then it runs smoothly. Should I be looking for something?
Also, there is a hum from the trans. at about 62mph in o.d. With the o.d. locked out no noise????
Any ideas appreciated.
Old Dec 14, 2004 | 04:36 PM
kenwhelan's Avatar
kenwhelan
Could be a miss. Loose plug wire, bad plug etc.
I've had this before and had rough idle with it.
kw
Old Dec 14, 2004 | 06:14 PM
Aftrmidnite's Avatar
Aftrmidnite
Its Vapor in the fuel rail, Ford tried to tell me it was a "Garage Effect" from the computer not knowing what temperature the engine was running at. It does it when its really hot outside and the truck is parked in a cooler garage overnight, or not driven in a week. Try this, turn your key to run, but not start and back to off. Repeat 4 to 5 times. If it greatly diminishes the problem then thats it. For you transmisssion you need to keep up on the fluid/filter changes with the pan pulled and converter drained. Make absolutly sure the fluid that written on the tranny dipstick is used, or you'll be replacing the transmission. If the pan has never been pulled there will be a plastic plug in it.
Old Dec 16, 2004 | 12:32 PM
Goudey's Avatar
Goudey
This helps alot!
I did the thing with the key and it seems to take care of the problem as it started up real smooth.
Thanks for the help!
JTP0110
Apr 9, 2007 01:46 PM
racerx6466
1997 - 2003 F150
Jan 2, 2007 11:18 AM
kingfish
Feb 19, 2005 07:54 PM
fiddler5.0
Sep 11, 2003 06:49 PM
