460 e150
Old Dec 14, 2004 | 12:56 PM
highrider76's Avatar
highrider76
460 e150
hi guys
I'm new to the whole van thing
I came upon an 84 e150 with no engin or trans for free.
A buddy of mine has a 500 horse 460 what would it take to put the 460backed by a c-6 in this ex 302 equiped van?
Highrider
Old Dec 14, 2004 | 10:32 PM
pfogle's Avatar
pfogle
Motor mounts... THe 84 was a coumputer controlled carb setup on the 302, so you will need an MSD or similar ignition system. YOu will also need heavier springs on the front. Seeing as the old engine and trans are already out of the way, it should be failry easy.
Old Dec 14, 2004 | 10:34 PM
highrider76
motor mounts
who makes headers/and motormounts that will work
Old Dec 14, 2004 | 10:47 PM
pfogle's Avatar
pfogle
You can get the motormounts out of any 74 to 92 E250/E350, and you probably wont find headers to fit.. You will either have to custom fab them, or go with stock manifolds from an E250/E350.
Old Dec 15, 2004 | 09:30 AM
highrider76
cheaper swap???360 c6
Hi guys I may have found a cheaper swap
would a the body from the van sit on a 2wd 1976 f250 chassis? I have the truck out back but forgot about the option of just putting the van body on this chassis. Yes the 460 would be cooler. But why buy a motor when I have a running 360 c6 package.
I was thinking of just stripping the body off of the rusted out truck. unbolting the van from its frame and just rolling the truck chassis under the van.
have any Idea how much of a difference there is in frame and mounting pads on the two chassis?
Old Dec 15, 2004 | 10:59 AM
pfogle's Avatar
pfogle
The van frame is wider, you could swap everything from the F250,....
Old Dec 15, 2004 | 11:07 AM
highrider76
When you say everything do you mean just the engine and trans?
Will front springs interchange?
Old Dec 15, 2004 | 11:41 AM
pfogle's Avatar
pfogle
The springs, front and rear will interchange. I believe the '76 has front leaf srpings so that may require some custom fabbed mounts, but everything else should be pretty straight forward, GOOGLE 4x4 ford van and there is a website by a guy that did a similar conversion.
Old Dec 15, 2004 | 12:30 PM
highrider76
The truck is a 2wd not 4
I just wanted to lift the whole van body off its frame and out it on the 2wd truck frame
Old Dec 15, 2004 | 02:51 PM
ACESN8S's Avatar
ACESN8S
I'm sure it could be done, but it would probably be easier to try and stuff the FE where the 302 was.
The van frame is wider than the pickup. And I think that it is a totally different design.
FE's weren't available in vans, to my knowledge. So you will have to modify a set of motor frame towers. Don't forget you will have to relocate the trans mount and get another driveshaft made.
My advice, get out a tape measure, pen and paper, and start measuring. That's the best method I know of.
Patrick
Old Dec 15, 2004 | 03:43 PM
WillyB's Avatar
WillyB
First thing to measure is the wheelbase, and then the distance from the front wheel to the front of the frame -- I'll bet they are different!
deshet1980
Jan 20, 2020 01:38 PM
Biggie84
Jun 28, 2017 04:50 AM
DerekShiekhi
Feb 22, 2016 07:55 PM
rlentz
39
Dec 24, 2010 08:17 AM
highrider76
Computer Chips & Tuners
Jul 10, 2003 05:30 PM
