Code 427 - Help Please
Old Dec 14, 2004 | 10:08 AM
CampingFamily's Avatar
CampingFamily
Code 427 -- Won't high idle.
Code 327 -- EGR low voltage code
What should I look to replace?
1992
302
E-150
Auto
140K miles
Thanks,
Marc
Old Dec 14, 2004 | 01:20 PM
jwtaylor's Avatar
jwtaylor
You should pick up a haynes manual, follow the steps to check the individual solenoid and sensors, you will need a multimeter. There are only a couple different things to check, not as overwhelming once you get in there and read more about it. A good place to start would be the evp sensor (connected to the egr valve). Good luck
